I live just a few miles from Ashland
Did anyone else think that Lake seemed genuinely surprised at their claim, at being the only oil company with their own engine test lab? He didn't call them out on it, and went with it, but initially, it seemed to throw him that the Valvoline guy was making that claim.
Yeah I'm not sure why that is.Yea, up untill recently, some called Valvoline just a blender. This is very cool actually that they've come up with a molecular entity to accomplish this. They have the money now and are ahead of many others.
Good job Valvoline
Are other engine oil companies not also doing that?"How the heck can you do all this if......you can't see all the nuances going and everything going on in the oil while it's in application." - Roger
Will post a filter in a few months like I did the HPL EC30 …I'm interested but waiting for folks to post photographic anecdotes which may take 6-12 months. I saw someone recently did but seemed like a sketch claim where the oil cap kissed some metal.
Its been an observation here, just only a few here that have hard-on against Valvoline. The issue here is the product launch staged marketing that shouldn't happen in the first place and let the product speak for itself over the course of time.I've tried telling people that before. It was in plain English at a 1st grade level for everyone to see.
The guy in the video is the guy I emailed. He's the one that said it was new technology.
Notice how he said you need an engine lab to pick up on the nuances. Without it you're guessing.
I appreciate LSJ and Valvoline doing this video. Good job.
This was after just one oil change at only 4,000 miles. Polar base oils are great at mitigating deposits and can clean deposits when at very high levels like the original restore oil they made. But this guy said this new chemistry goes even further.
They kind of contradict themselves by saying a couple minutes later that their old product, full of ester, cleaned too muchHe also said that oils with the polar base oils are very good at keeping the deposits to a minimum, but this oil moves it to a negative. They know of no other oil that can do that.
They are right to a degree, which mention filter plugging is a concern. Seal compatibility comes too mind as well. What happens if we put too much esters based oil in the motor? I haven't seen any documentation of main seals leaking crazy. However I trust the chemist's concern when other factors and drawbacks come into play...They kind of contradict themselves by saying a couple minutes later that their old product, full of ester, cleaned too much.
I suppose the cleaning when using esters depends on the type and quantity. Also high end oils that use esters that have that polarity are going to keep pistons clean to begin with.
This is the exact prevailing factor in my maintenance plan.What stood out to me is when he said they've gotten so good at keeping deposits to a minimum when using these polar base oils, but this new R&P flips it to a negative, I guess meaning it completely removes them.
As LSJ said, on paper you'd never know it. But it's been said a million times on here that what a VOA shows doesn't tell the entire picture. The original R&P had a very hefty does of POE. I believe they said it was near 50%. Oxidation value of that oil was 130.
This is an Amsoil SS piston after a double run of that IIIH test they're referencing. Clean for double length.
The piston skirts look better with the R&P than what the BG photos show. In the BG piston photos, the skirts still have the same level of varnish. Notice the R&P photos. Also, look at how they jacked up the lighting on the BG second photos. (look at the white/black contrast ratio). In the Valvoline shot, it's two pistons from the same engine on the same table under the same light.Its really interesting how clean the lower end of the piston is compared to the top. Of course we have very little visual data on before and after teardown using high solvency oils such as Amsoil & HPL, that would be a pretty cool comparison to reference those pistons seen on the video.
Anyways heres a visual comparison of BG's EPR demonstration of a solvent based flush that agressively cleans the ring land areas. Notice the ring lands between the 2 upper and lower compression rings, look quite cleaned up. But the Valvoline we see here still has that region still caked up with carbon...
Here is Amsoil piston cleaniness example.
Yup me too.Looks like it only comes in 20-30wt flavors. Wonder if they will make a euro 40wt version
Yup, and my experience with HPL, I was shocked at how much crap was liberated during an OCI on a clean engine only ever run at the factory intervals with premium oils. Now, the HEMI is a dirty running mill, but still, that was surprising. You wouldn't want that kind of rapid cleaning in your Joe Average OTS product, because the odds of rapidly plugging up the filter on a neglected mill would be extremely high.They are right to a degree, which mention filter plugging is a concern. Seal compatibility comes too mind as well. What happens if we put too much esters based oil in the motor? I haven't seen any documentation of main seals leaking crazy. However I trust the chemist's concern when other factors and drawbacks come into play...
As for HPL, they don't recommend exceeding 20-25% using EC30 which also has a high oxidation value per @RDY4WAR oil analysis sample, for similar reasons.
I believe the key wording is an “ASTM Certified” engine test lab. You can have an engine test lab in your garage, but is it ASTM Certified?Do you guys really see this as anything but a thinly veiled ad?
Edit: I'm in the middle of watching it now. Valvoline R&D is claiming that they are the only PCMO company that has their own engine test lab. Do we have anybody here who can credibly dispute that? I find it mighty hard to believe that XOM or Shell doesn't have their own engine test lab too.
