K20C4 Oil Selection Sweepstakes is over (2022 Accord)
Diesel Central, Indiana
The 2022 Accord I bought early this year is a car I plan to keep for a long, long time. The 2.0T turbo and 10speed really feels like a special setup, and is no longer available in an Accord.
I currently have VRP in it while I figured out my longer term oil plan. I have posted about perhaps an HPL Supercar 5w40. I have highlighted the Valvoline Euro oil which seems to get very little love.
After spending a LOT more time than I should have endlessly internally debating which HPL oil to use or whether use to use M1 ESP 0w-30, I finally made up my mind: Valvoline European Vehicle Full Synthetic XL 3 (VEVFS-XL3). It just rolls right off the tongue, doesn't it? When even the acronym needs an abbreviation..... VE3? VEVFS3? I digress.
Why this oil? Why not something like M1 ESP 0w-30 or ESP 5w30, those BITOG darlings that they are? It's a combination of minor technical differences plus some emotional/sentimental/philosophical reasons.
--C30/504/507 *and* API SP. Not a ""meet or exceed requirements" (ESP 5w30) or a "meets engine test requirements" (ESP 0w30) but a no-kidding actual SP license coexisting with C30. My Accord can hit 15psi of boost at 1500 rpm and LSPI is a potential (not saying likely) issue.
--I will not be doing extended drains at first (sorta kills HPL). I want something I can dump at 5k and not cry about wasting liquid gold. I expect that I will at some point work my way up to HPL and 10k intervals, but even then that's simply the break-even cost on HPL Euro relative to VEVFS.
--Slightly higher Kv100 in the Valvoline vs M1 ESPs.
-- I like this Valvoline bag-in-a-box packaging. It basically a keg, and we all know good things come in kegs.
-- I can get this from NAPA and support a small locally-owned retailer for a reasonable price ($35/gal). My local mega-mart has the ESP in plastic jugs for $28. I'll pay the premium to support the smaller oil company and the smaller retailer.
-- I'm a bit of a homer for Valvoline since I've made my living professionally dependent on Premium Blue (all USA Cummins engine development is performed on Valvoline Premium Blue and several of us gray-hairs here still remember or are even friends with Roger England).
-- I don't need a 0w oil and I prefer a thicker base oil. Base oils matter for MOFT and 5w is the balance between as thick as I wish and unquestionably capable for Indiana winters. This oil is a PP of -36C, that's plenty.
-- I really wanted a Euro add pack and the >3.5 HTHS. This is the primary reason to prefer this oil to regular VRP 5w30. The VRP has both lower KV100 and VI. IMO the Euro oils are the perfect middle ground between the marginally low HTHS of a regular SP 5w30 (~3.1-3.2) and a 40 grade. While I might eventually work up to a 40 grade, I wanted to baby step my way to the thicker oil and see how it goes. The low operating temp of this engine likely put the oil closer to effective 40 grade range anyway (coolant temps run 170°F-175°F and I've yet to see over 180F.
I've been very pleased with VRP so far and I cannot complain. I'd pull a sample when I drain my current VRP, but I wouldn't be honest to pull single sample from 20k-25k of engine life and compare to 25k-30k or so. And mostly I really prefer the "stronger" oil that is a Euro oil-- the stronger add pack and the stouter viscometrics.
Now, give me VRP with the Euro viscometrics and add pack and I'd probably faint. For now, though, I'm satisfied that this oil will work very well for me for a couple years (there are 5 OCIs in this box).
That’s something.
Also, you can easily verify whether an oil has a VW approval or an API license. And, “meets or exceeds” is a proper statement for an API license.
Your continued fawning over a particular brand is not entirely substantiated.
In addition to the 5w30, using premium fuel also helps. Even though Honda says you can use regular, turbos really should use premium.
The favorite 5w30 Euro is the PP Euro L due to price and availability at Walmart, but the XL3 should be just as good :)
What kind of driving conditions? Short trips, long highway driving? :unsure:
Nothing but V Power Nitro 93 for my Accord. I agree completely.
My car sees predominantly highway with some short trips. The MPG average since I installed VRP is 29mpg over the last 2500 or so miles. The EPA mixed cycle rating is 26mpg at 45/55 highway/city.
If you can get your hand on the euro manual, I guarantee you it’s gonna tell you to run pretty much whatever you want unless you want the best fuel economy at 0: 20 but other than that Honda is super easy on what they recommend outside of the United States
Yes. The best i could find was the UK owner’s manual for the Civic Type R. That manual specs a 5w30.
I’m coming around full circle these days on viscosity. I used to think it didn’t really matter, then decided it was super important, and now I’m back to thinking it probably doesn’t matter as much as think.
Troll the UOA and you’ll find lots of great UOAs with 20 grade, 30 grade, and 40 grade alike.
The UOA does not you anything In regards to the amount of heat inside those bearings, the rings, the turbo gets extremely hot, extreme high rpm. Only one reason for 20wt is cafe and the mfg trying to squeeze every drop of mpg out of an engine. The only thing they care about is the engine makes it past the warranty. There is a reason why euro oils also require a min of 3.5 HTHS
In your accord. I would honestly run M1 0/40 with that 2L Turbo and always allow for a min of 1 min cool down time before shutting it off.
The turbo is water cooled and a minute of cooldown is completely unnecessary for anything this side of a racetrack.
The amount of oil flow it takes to lubricate a journal bearing turbo is tiny. Back in the day, turbos had very high oil flow because most of the flow was for COOLING. But with a water-cooled bearing housing, you only need enough oil flow for lubrication, which is very little (< 1L/min).
A minute of idling does almost nothing to cool this engine further. Moreover, the coolant temps are pretty low with an 85°C max in my monitoring.
I'm not opposed to M1 0w-40. I just don't see that it offers me much of anything over the Valvoline Euro which has tons of approvals also. Arguably the FS 0w40 is closer to a full-SAPS where the Valvoline is mid-saps, but I'm not yet ready to switch to full-SAPS in this TGDI engine.
That’s not the point of cool down time, the point of cool, down time to allow the turbo to spin down to idle speed, and the bearings cool. You drive your car you come up to a stoplight off the freeway that turbo still is probably spinning over 10,000 RPMs. If you shut it off, you have no coolant flow no oil flow. The bearings are spinning dry. That’s also how oil coking forms. You also don’t want to spin them full speed until you have min 185 coolant temp.
The bearings are already cool from being surrounded by a water jacket.
The turbo spins down in seconds. This isn’t a ball bearing turbo, and it’s got a tiny inducer (<45mm) and journal bearings have a fair bit of viscous drag from the oil that lubricates them.
I’m sure this turbo spins over 10,000 rpm coming off the freeway, because it’s probably spinning that fast at idle. The rated RPM of a turbo this size is 150k rpm or higher in some cases, so 10k is closer to idle speed. On the dyno, I’ve personally seen much larger turbos pushing 112k rpm, and that was a HE400 series turbo for a 600hp X15. 150k rpm for a turbo this tiny is a walk in the park.
If you shut it off, you lose coolant flow and oil flow of course. But the bearings are not spinning dry whatsoever. There’s oil retention features in the bearing housing and it’s not like you’re spinning it for 30 seconds with no oil pressure.
Finally, that’s not how coking forms. Coking is a complete non-issue with a water cooled bearing housing.
I mean no disrespect when I say this: your understanding of turbochargers and reliability risks is about 40 years out of date.
