The engine isn't nearly as picky about viscosity grades as we BITOGers are.
While I disagree with much of Dr. Haas' writings, he's not wrong that every oil is too thick when it's not warmed up. At some temperature, the "w" grade matters much less than the main grade. In a warm climate, this point is below almost all regular oil temps you encounter.
A thick 20 grade at 90°C might be significantly thicker than a light-end 30 grade at 105°. Which means that staying with the "thin" oil means running "thick" oil in the context of persistently low average oil temps.
Remember, the grades are just snapshots at a particular reference temperature. The actual running viscosity depends on your temperature and your usage. This is why the newer hybrids are calling for the 0w-12 and even 0w-8 oils. It's because those oil are only "so thin" in the context of the KV100. If you monitor the average oil temperatures of these hybrids, you'll find that at the common temperature, these thin oils are much closer to a 20 grade's viscosity in a constant-run application.
One could argue that even your driving style matters in a street car. If you drive aggressively and get poor MPG vs other drivers, you probably have hotter oil temperatures than those drivers, too, and should have an oil that's a higher SAE grade.
Conversely, if you drive like the proverbial little old lady, maybe a 20 grade is a "thick" oil for you.
Which sort of raises the question as to whether we should all install oil coolers so we can run thinner oils and still have them be thicker in the engine, eh?
