Originally Posted By: joel95ex
Everything has held up well, but replaced both CV axles about 6 yrs ago, replaced a radiator and both fans, starter, original alternator went out last year, did an acura CL rotor/hub conversion so brake jobs are easier, replaced the inner and outer distributor o-ring and shaft seal, and 3 timing belts---- the first one was done free since the balance shaft seal (recalled) popped out on the highway. I have used supertech, castrol GTX, Pennzoil conventional, Pennzoil Platinum, and Mobil 1. I switched to the syn mainly for extending the OCI's since I do a tone of driving for my job. It is the original auto trans, but I do the partial drain and refill twice per year since you only get 2.5 qts out of the 8 or nine each time you drain. I will post some pics tonight or tomorrow.
Don't you know that changing to syn after the car has some miles will ruin your engine? No way this car makes 500K after you made such a dumb move.
