It's not that the oil you use matters, it's when you change it. People prefer synthetic for better cold flow & extended change intervals. Whether or not you should use conventional, blend or full synthetic depends on YOUR application, YOUR conditions & when YOU want to change it. All 3 will push your engine for hundreds of thousands of miles if changed at the appropriate intervals. Conventional changed every 3,000-5,000 (depending on conditions) will keep your engine running forever. Synthetic blends changed every 5,000-7,500 will also do the same. Full synthetic every 7,500-10,000 or beyond will do the same as well. You pick the oil appropriate for your vehicle & conditions & change it accordingly.
