JTK
$100 Site Donor 2025
I recently bought a pair of Phillips daylight 5000K 48" T8 LED "plug and play" tubes to try in an older T8 fixture at home. No go. They wont light. These retrofit tubes are designed/marketed to be used WITH the existing ballast. No ballast bypass. Given I wanted to swap out a cheap T12 fixture in the garage anyway, I bought a new cold temp start T8 to try these LED tubes in. STILL no go. From what I've read online, these tubes won't necessarily work with all ballasts. Back to Home Depot they'll go.. They were under $10/ea FWIW..
