Originally Posted By: Trajan
Originally Posted By: rdalek
Originally Posted By: MolaKule
Originally Posted By: Vikas
Guys, *I* ran out of popcorn a while ago; this movie needs to end now! Anybody else *not* yet bored with this utterly useless urination contest??
That decision would be up to the mods.
So, you guys can't explain why ZMax can still make basically the same claims
Quote:
zMAX soaks into metal
What is the physical/chemical theory and instrumental proof that this occurs?
Quote:
zMAX reduces friction
All lubricants reduce friction but in a relative sense.
Quote:
zMAX increases horsepower.
By how much and by what standard?
Quote:
zMAX dissipates engine heat
All lubricants have a thermodynamic conduction coefficient which allows heat to be conducted via thermo-fluid interactions. What makes this product different?
Quote:
zMAX helps to improve or restore gas mileage and reduce emissions in older cars, by virtue of reducing engine deposits.
zMAX helps to maintain gas mileage and emissions in newer cars, by virtue of reducing engine deposits.
zMAX helps to reduce engine wear on engine valve-stems and guides and piston rings and skirts, by virtue of reducing engine deposits.
zMAX helps to extend engine life, by virtue of reducing engine deposits.
We'll give them
by virtue of reducing engine deposits if they can unequivocally prove it.
Your answers are? Zarch can't explain it. Oil Chen can't. Your turn.
Apparently the FTC got it explained to them did they not? After all, they stopped fighting in court to stop ZMax from making basically the same claims. As I said before, until you can explain why the FTC still allows ZMax to make basically the same claims, your reply is a waste of time. By all means tho, keep wasting your time. You reply with the same thing, I'll reply with the same thing too.
Originally Posted By: dave1251
The makers of Zmax can not make the same claims. Your posts are well written but asked the same questions and have been answered. No question from zmax supports have been answered from a chemical, technical, nor legal standpoint.
Also it will help your cause if you can provide the money back guarantee in writing from zmax.
They are making basically the same claims. Some have not changed at all. See previous replies by dave5358 since he has them listed already.
http://www.zmax.com/contact/
Quoting from the site, emphasis added by me:
Quote:
150,000 Original Mile Guarantee Questions: 888-645-1101 (In the event of vehicle component failure, for refunds under our
money back guarantee, please call customer service number 888-645-1101.)
I hadn't looked before but recall seeing it on a TV commercial many times before plus saw it mentioned in a post on this thread a ways back. I've been seeing the commercials for a long time and recall that as far back as I care to recall.
