I posted this in a Miata forum, but I thought I'd post it here as well to see what opinions I got.
I bought my 1995 Miata last September, with 139k miles on it. It had sat for much of the past year before I bought it. When the weather got colder, it would occasionally blow a huge blue plume of oil smoke on cold startup. Because it only happened occasionally, I thought this was due to gummy oil control rings. I added about a pint of Marvel Mystery Oil to the crankcase, which I had changed to Mobil 1 5w-30 full synthetic, and took the Miata on a long, hard driving trip, which seemed to clear up much of this problem. The MMO also made the hydraulic lash ticking noise go away much more quickly on both cold and warm startup. After the driving trip, the engine ran much more smoothly, fuel economy increased by 10-15% (probably also attributable to Techron that I ran the engine time), and oil consumption decreased.
I changed the oil to full synthetic Rotella T6 5w-40 at the next change. My Miata did not take well to this. It started blowing the oil plume on cold startup again, and I'd get HLA noise for a minute or more occasionally on cold startup. However, instead of changing out the oil, in a fit of laziness, I dumped about half a pint of MMO into the crankcase and these symptoms went away.
This is the oil that is currently in there. It's approaching 5000 miles, and as it has gotten older, I'm burning a little more oil, maybe one quart every 800-1000 miles or so. I've also gotten more ticking on both warm and cold starts. The previous time the oil was low, I topped it off with Pennzoil Ultra 5w-30. Because I'm about to change the oil again, just today I decided to top it up again with some MMO to do a bit more cleaning.
I could not tell any difference when adding about 2/3 quart of Pennzoil Ultra. The engine ran the same and started the same. However, today, after adding about half a pint of MMO, the engine is clearly running more smoothly, both on idle and when revving. There is **zero** HLA noise on startup. I had occasional idle dips to about 500 RPMs when declutching, and that has gone away. I haven't had an oil plume on startup in months, and there is none now.
I'm pretty perplexed by this. MMO are light solvents in about a 5 weight oil, and it shouldn't have this kind of effect. It's also a slow cleaner and not a flush-type of additive. So the difference is engine smoothness and startup ticking must be due to the difference in oil properties by adding the MMO.
This last time, the Miata definitely didn't care for the thicker 5w-40 Rotella T6, but the initial adding of MMO to thin the oil made the oil plume and startup ticking much better, and now on the old oil which is probably even lower in viscosity, thinning it some more has made the engine run more smoothly. I'm really tempted to try a 0w-20 oil just to see if it is the low viscosity that is providing the benefit.
What is it in MMO that would have this effect on the engine?
