You will be fine. LOLIt's called OCD.
I do a 20-25% run of MMO w/ HDEO 15w40 in my older cars every couple of years in the summer months. When I did the valve cover gasket on the 2008 Corolla with over 150k, it looked fantastic.
5k. Funny, I actually got a couple 38 mpg tanks over the summer during this run also.Really, how many miles do you do this 4?
Do you have to add oil or does the level decrease on the dip stick when you go this long with MMO in the oil?5k. Funny, I actually got a couple 38 mpg tanks over the summer during this run also.
How long do you keep it in the oil?Perfectly fine, I've added a qt to my Civic various times with no issues whatsoever.
I've added it during a fresh change and you can leave it in for the whole interval, if you need to top it off later just add oil.How long do you keep it in the oil?
So, I didn't realize that I had this currently in the Corolla. It was a 25% ratio, so 5% more than the recommended 20% ratio. Mixed with 3 quarts of Mobil Delvac 1300 15w40. One of the kids has the car so I wasn't able to check like I usually do. Turns out, it was at 76xx miles on the OCI so way over where I wanted to change it out. Just under 3.3 quarts came out, so definitely burned some mmo up. The Corolla is at 172,xxx now and really doesn't care what oil we run in it. Current fill is QS Advanced 5w20 for the fall/winter.Do you have to add oil or does the level decrease on the dip stick when you go this long with MMO in the oil?
I’ve always heard that the MMO flashes off but I’ve never left it in the oil for long.
If not done already I’d be more worried about that timing belt change vs adding mmo to your oil.My Ridgeline just turned 104K miles after almost 17 years of ownership, where my average OCI has been 5,300 miles using quality blends or full synthetics. I don't suspect much if any varnish or sludge in the motor, but I decided to add 12 ounces of MMO for the final 250 miles before my next oil change. Honda states in its owners manuals that it doesn't recommend using any oil additives. Is that a concern, or should I just leave the MMO in for 250-300 miles with no concerns?
Timing belt and related parts were replaced based on age instead of mileage: 9 years and 75K miles. I'm the original owner. No way I'd ever wait 17 years for that.If not done already I’d be more worried about that timing belt change vs adding mmo to your oil.
