I have a '06 Mazda Tribute (Ford Escape) with the CD4E transaxle.
The tranny drain plug is right next to the crankcase drain, so it's a extra 5 minutes to dump the ATF.
A ATF dump and fill will change 4 out of 12 quarts,so the question is would it be better to do a partial change at every engine oil change (5000miles) with a regular ATF fluid like Pennzoil, or wait until 30,000 for a full flush? Would I even need to flush at 30K if I've been doing the partial all along? Since a gallon of ATF is like $8, cost really is not an issue.
BTW I did install a Magnefiner filter in the cooler lines that will be changed every 15K.
Thanks!
Drew
Thanks!
Drew
