Owen Lucas
$100 Site Donor 2023
- Joined
- Sep 5, 2021
- Messages
- 3,008
My latest video:
- I removed the power steering reservoir and soaked it in an ultrasonic cleaner for 1 hour with a 10% solution of Simple Green Aviation Cleaner.
- Drained and refilled system with new Liqui Moly Top-Tec 1100 ATF (Dexron III).
- Added Liqui Moly Automatic Transmission Cleaner to the new fluid to see if the chemicals would clean up any sludge in the system. This would be visible with through the temporary clear tubing in the supply line to observe for color change of which none was noticed.
- It's not in the video but I flushed the PS fluid out again to remove the ATF cleaner out of the system for a final fill of Top Tec ATF.
- Finally added LM Power Steering Stop Leak.
- 2005 Scion tC 180k + miles. Mostly original fluid, topped up occasionally.
