Enlight
The only problem I can see with your plan is the radiator will cool down the coolant that's returning to the heater. I would cut the radiator out of the loop for maximum heating of the engine.
I'm seeing coolant temps hit 219f and I suspect that it's because coolant is bypassing the radiator through the pre-heater. I thought the pre-heater lines would be sufficiently small that it would be insignificant, but after burping my coolant system the temperatures are still high. This wasn't so much of a problem in the winter.
I thought about installing a "reverse" inline thermostat (open when cold, closed when hot) on the pre-heater supply line but I don't think such a thing exists. I think I will just go back to my original plan of supplying from the bottom radiator hose. I could also tap the turbo's coolant line but that's a long length of line to run.
