Is CAFE the 'voice of reason??'
I don't pay attention to CAFE. Some of the experts here have advised some of us against thicker oils based on MPGs, HP, Flow in cold weather, etc....that's why!quote:
Wow, that's a surprise! I thought it would be something like a 5/10W-40.quote:
Originally posted by Losiho:
It was posted in another thread a few days ago - the factory fill for the HSV LS1s is Mobil 1 10w30. I'm not sure what the "run of the mill" Gen 3s use, but I don't think the viscosity would be any different.
Doug,quote:
This synthetic Shell oil was in the car for 12 months and four samples were taken
The car is now on Mobil's Delvac 1 5w-40 and there was a noticable difference in the "feel" of the engine after the change
It's true, Mobil 1 5w30 and 10w30 don't show the best results in the LT1 or LS1 engines that go in the Vette. These engines like an oil which is a thick 30wt to a low 40wt, so bearing wear is higher in these engines when using the thinner Mobil 1 30wts. It's not dangerously high, but it is noticeable that the slightly thicker oils do better in these engines.quote:
Originally posted by Jelly:
And while I'm not Vette expert, I do know that the best analysis numbers are not turned in by Mobil 1 on the Vette. Wait till Pat chimes in here...he'll set you straight with your Vette.
So, John now you know what to try next!quote:
If anyone was woundering wear all of the American made 0W30 Castrol has been ending up it is in my town! They keep replenshing stock with yellow label 0W30 with dust already on the bottles!
TooSlick, a couple of questions:quote:
Originally posted by TooSlick:
This is how the highest quality, PAO/Ester based, 0w-40 will behave in a four cylinder, high performance engine:
After 5000-7000 miles, it will turn into a 5w30 ...
Note: The low temp properties are most effected by evaporation of the volatile parts of the basestock and not by oxidation. Oxidation occurs later on ....
After 10,000 miles, it will turn into a 5w-40 ...
After 15,000 miles, it will turn into a 10w-40, or maybe even a 15w40...
Between 15,000 and 20,000 miles, it will thicken right off the scale, due to total depletion of the antioxidant additives, and evaporation of the most volatile parts of the basestock.
Try this test in a Honda/Acura, V-Tec engine and see what happens. It won' t be pretty ...![]()
I'm not TS, but I thought I'd chime in here. The whole "one size fits all" tempt with the 0w-40 is a good idea, but it's just to large of a gap. Unless your using a higher quality base stock, like Red Line or D1, a $5qt 0w-40 isn't going to be a good choice. I still prefer oils like 10w30's with no VI's.quote:
2. if a 0-30 is better than a 0-40 with respect to 'staying-in-grade' then why would any manuf. recommend a 0-40 over a 0-30?
3. can not the same statements hold true for any multiviscosity oil except maybe to a lesser degree/extent?
