Quote:
Thicker can be a fail-safe choice. ....... Fuel dilution is becoming more of a problem in modern engines and thicker oil might supply a little safety margin. Putting 20w oil in an engine that specifies a 60w requires some consideration, The uoa's may not prove that one is better than the other but it does show that the engine is not at risk for a lubrication failure.
Quote:
""Next I go to Bruceblend 20w-50"'
Gary is that the ASHLESS AW pak, NON VII, shear stable smells like bubblegum one?
LOL
bruce
Quote:
I just don't see any good reason to go with a 20 weight unless one is doing very short trips in a very cold environment.
Quote:
IMHO, 20W-50 and other relatively thick oils will protect any road car engine perfectly well. Thinner oils have been developed to protect as well as thicker oils under non-extreme conditions of heat, with a small improvement in fuel economy. If you don't care about the small improvement in fuel economy, the thicker oil will work well.
In my experience, car manufacturers in Australia give a wide range of choice. Toyotas for example, list a 30 weight for better economy but 50 weights are able to be used and are often recommended in extreme heat.
Quote:
I'm just sick of everybody with viscosity phobia. If the filter isn't blocked and the oil pump is working reasonably and the oil is reasonably 'clean' your engine will run forever. Vehicles here run 0W20 to 40W70 and 40yrs old on original engine.
Quote:
Dr.AEHaas is it too much to ask for a test like this one? ken4's test
I think it is a fair comparison.
I do not put on enough mileage.
Quote:
DR.,
have you ever considered doing the ferrari driving experience?
http://www.experienceferrari.com
