WOW Doc..I think I got it..the T&S 5-40 that I use in my 454 GMC with 4:10 gears seems to work pretty good..it usually runs at 3k RPM all day long pulling a 8k# trailer..
Unfortunately, this is the same issue with the kind of info AEHaas is asking for. If the research 'waits' until after the product has been finished and gone to market, it is after the fact and thus useful only as a tool to improve upon the succeeding formulations.quote:
What is the weakness in UOA (other than it is after the fact).
I mean no offense JAG, but I believe that is a really dumb idea for someone in Florida. 180° F is comfortably in a safe operating range. I'm confident many people would be quite surprised to find out that many of their own vehicles normally operate in this range of oil temperatures unless they're running it at the track or towing up a mountain.quote:
As someone else said, I'd also look into blocking off part of the radiator and/or oil cooler to see if you can get the oil closer to 210 degrees (or whatever you prefer).
Good point, Jaybird. Too little discussion on elastohydrodynamic lubrication and boundary film-strength properties.quote:
Being a simple layman, I have to conclude that the HTHS thing is way overblown as a indicator of a fluids performance, and the actual barrier protection aspect of the fluid (be it from adds or base) is far more important.
Most oil cooler thermostats open at 180° F, so I don't believe blocking the oil cooler is going to help significantly below this point.quote:
I agree that 180F is not too bad but it's still not ideal and given that the temps on other occasions got to only 160F which is certainly less than ideal
