wemay
Site Donor 2023
There have been quite a few Theta with this same result that used 3.5 HTHS oils. You either have a good one or a (relatively speaking) bad.
The Theta II is doomed no matter what you do, if it wants to seize up or throw a rod it will, even if you fill it with straight 50 and drive it like a grandma.There have been quite a few Theta with this same result that used 3.5 HTHS oils. You either have a good one or a (relatively speaking) bad.
The 2006-2010 NF Sonata is arguably Hyundais most reliable vehicle. Along with the first generation Hyundai Santa Fe.292K on a 2006 Sonata when I sold it running great. When did the problems start?
A well designed engine should have absolutely no problem being worked hard and lasting. Lord knows how many 302 HO Ford engines were over-revved, banged off the 6,250RPM limiter...etc and went hundreds of thousands of miles. I sold mine with over 200,000 on it and a good portion of it was making 100HP more than stock.I am wondering why people have to run engines so hard. Maybe a lot of 4,000 + RPMs are not a good idea.
Lol so people have to drive on eggshells with certain brands just so they don’t fail?I am wondering why people have to run engines so hard. Maybe a lot of 4,000 + RPMs are not a good idea.
Gives the term "positive crankcase ventilation" a whole new meaning.
It’s called implied warranty of merchantability. The manufacturer did not advertise and sell a vehicle with a chainsaw engine, they sold an automobile with an automobile engine. Neither did they state in the owner’s manual that operation above 4000 RPM could result in damage nor do they rev-limit the engine to operation below a certain level.We were not discussing a well designed engine, were we? We were discussing a Hyundai engine. We also were not discussing a chainsaw engine. If you abuse a cheaply designed and manufactured engine expect negative results. If you want an engine that can take that, buy one designed for it.
You just said "engines", you didn't say THIS engine. You made what came off as a very broad-brush statement and didn't seem in any way to be exclusive to the product mentioned in the OP.We were not discussing a well designed engine, were we? We were discussing a Hyundai engine. We also were not discussing a chainsaw engine. If you abuse a cheaply designed and manufactured engine expect negative results. If you want an engine that can take that, buy one designed for it.
I absolutely loved the Ford 302 engines. I had two that were not the HOs yet still were a joy to own and operate. They really hit a home run when they developed those 5.0 engines. My 1994 had only 205 horsepower yet it felt like 305 when you stepped on it. That truck was a blast to drive on the highway when there was room to open it up and go............... But you could not go past too many gas stations. I abused and used and pulled boats and ran that truck like mad and never had one mechanical issue. I had a similar 302 version in my 1986 full size Bronco that was good too. Only issue was about once a year I had to clean the throttle body & flap for some reason. At one time I even toyed with the idea of putting a Ford 302 in one of my Chevelles! Some Chevy folks would freak but I have seen similar in guys hot rods + cars... Some auto guys just like to have fun no matter what brand.A well designed engine should have absolutely no problem being worked hard and lasting. Lord knows how many 302 HO Ford engines were over-revved, banged off the 6,250RPM limiter...etc and went hundreds of thousands of miles. I sold mine with over 200,000 on it and a good portion of it was making 100HP more than stock.
The S62 in my M5 loved to sing and would explore every inch of that tach.
The 5.4L in our old Expedition would rev pulling hills with a trailer, again, over 200,000 miles on it when we sold it (and it's still going) and still running like a top.
There's no excuse for producing fragile garbage that won't stay together if you run it hard.
knock knock knock. the people bouncing off the limiter were the same people losing rod bearingsThe S62 in my M5 loved to sing and would explore every inch of that tach.
From my days on M5board, it seemed that it was the guys that tracked them that had the issue. However, there was one member with like 300,000 miles on his, original bottom end, who did periodically track it and ran Mobil 1 0w-40 in his. The S62 wasn't plagued by inevitable rod bearing failure like the S54 was.knock knock knock. the people bouncing off the limiter were the same people losing rod bearings
Yet I do this daily on my 183k Hyundai and it just doesn't care one bit. I drove 1200 miles to Georgia on the highway going 90-100mph over Thanksgiving, accelerating past 6500rpm to pass slow people.knock knock knock. the people bouncing off the limiter were the same people losing rod bearings
Those had mitsubishi engines, all of them up to 2004-2005 i believe. Elantra was probably the 4AG(EDIT***4g63***, my mistake was just watching old AE86 corrolla videos), good simple versatile powerplants, if a bit unrefined for the era. Their current powerplant design underpinnings can still be roughly traced back to those old motors. They started to have the big design problems when they started engineering their own engines. Their V6's seem to be reliable simple motors, their 4cyls very often have some kind of problem unless you do perfect maintenance, and even then it sometimes does not matter depending on the motor. I know alot of users on this board like their products, but alot of users here also seem to always have a car thats only 0-5 years old. If youre cycling through that fast, they can be good value, if you like to hold onto things or buy used, ya wouldnt touch them. Dont care about the warranty either, I hate feeling the car break on me and dealing with waiting for the car etc even if they give you a rental.Kia/Hyundai lost their way. (Grew too fast)
I bought an Elantra for my mother in 2000 I believe.
She ran it to death and sold it and had no issues with it.
@53' Stude I agree.
2011 when they started using Theta II GDI engines. Those are the ones with the most problems and have the lifetime warranty settlement. The engine in this thread is the 1.8L Nu MPI and some people had issues with it too.
I don’t know what went wrong with Hyundai after that. Their older 4cyl engines that I’m most familiar with (alpha, beta, gamma family) were solid little engines. Hopefully my 1.6L Gamma GDI in my Kia Soul will be just as reliable. Accent Abuser has almost 200k on the same engine, so there’s that.
I’m convinced that a lot (not all) of the failures are due to people not bothering to check or changing their oil. A Kia tech on the Soul forums kinda backs that’s up with all the over due oil change stickers he sees every day. But I digress.
Or the car has a garbage transmission instead, and all of the dead ones are bad transmission.When a motor is garbage design they cost a fortune because you can't find them since they are all blown up ! The Nissan engine must be a reliable one so there is no demand for the supply
Then the ECU should detune or cut power instead of let it run hard and throw a rod.I am wondering why people have to run engines so hard. Maybe a lot of 4,000 + RPMs are not a good idea.
Agree, if an engines redline is 7k, then the computer is usually tuned for 6500 RPM, and the real blow up speed is somewhere above that. I doubt many Hyundai's are grenading from being driven too hard, 99% of the time I see one blown up on the Just rolled into the shop subreddit or YouTube the engine was either one of their problem engines or the owner never changed/checked the oil, usually it's the latter. Hyundai and Kia (and to a lesser extent Nissan) seem to attract neglectful car owners for some odd reason.Then the ECU should detune or cut power instead of let it run hard and throw a rod.
