Someone I know has an '04 ML 350 (3.7l v6), and needed to park it at my house for a day before going on a long trip (long story in itself...). I noticed that the brakes were noisy, and upon inspection found that the right front rotor was literally desintigrating. Pieces of it would break off at the slightest touch, and the pads on that side were way worn into the hard metal. So I told her she would never make it to Florida like that, and offered to replace the front rotors and pads. No problem. Luckily the calipers were still ok.
Then I checked the oil and found...nothing. The dipstick was totally dry. So I opened the drain and what came out was like goopy black jello, one small teaspoon sized plop at a time. I asked her how long it had been since she had the oil changed, and she said, "Oh I don't know, maybe 40,000 miles?"
After picking up my lower jaw from my chest I filled the sump with Supertech 10w30, of which it took 4 qts to fill, removed the filter element (can't have been any worse than using the filter that was already in there--I should have taken pictures), and ran the engine for about 30 minutes. After that it started draining well, and I went for a new filter and 9 qts of Syntec 5w40, which is not a minor expense. It took 8.5 qts to fill it, which is about what it should take according to the Amsoil online guide.
It is amazing the thing is still on the road with about 240,000 miles.
