Cryptokid,quote:
Originally posted by cryptokid:
i have explained this before, but i forgot which post i typed it in. anyways it is awalys beneficial to let any_engine warm up.
when you first start the engine up the pistons, rings and exhaust valves are the first things to come up to tempature. now as we all know aluminum expands quicker than iron, so what do you think happens when youre aluminum pistons expand at a rate quicker than the iron cylinders can cope with? you guessed it, piston scuffing and loss of matereal.
the reason the cylinders dont expand just as quickly is a 2 fold answer. 1. aluminum expands quicker than iron when heated, and 2 the aluminum piston and ring set have alot less physical mass than a big iron cylinder.
to a lesser extent the same problem happens to youre exhaust valves when they heat up quicker than their valve guides which are encased in the big cylinder head. big head=lots of thermal mass.
this is for the same reason that piston slapping engines will often quiet down once they are up to tempature. the aluminum piston expands more than the iron cylinder and take up the space.
you cant ingore the laws of thermodynamics and just say it doesnt apply to youre engine!
Thanks for explaining this again. I have have a question.
Are you saying the dimension measured across the cylinder, the bore, is smaller or larger when the iron is cold?
As the iron comes up to temperature does this measurement slightly increase or decrease with heat?
