Cicero
Quote:
Quote:
....I hope this helps.
JMH
Yes, it does. I've done a lot of searching and reading and I'm coming around to a better grasp of this whole topic. Sincerely appreciate the help. I'll wait awhile longer on the first oil change for now and see what else I can learn. No hurry.
Thanks.
Quote:
In short, would you put so much weight on insisting on ..or defending the practice of ..this "do as you're told"..if it was a Chevy??
Quote:
Auto-RX is for cleaning dirty engines of deposits due to oxidation, nitration, etc, of the oil, not for cleaning out wear metals. Now LC or maintenance doses of AutoRX will help keep it clean. I'm not sure how soon you want to use AutoRX on an engine that is breaking in, but I believe you can begin using LC right away. I'd wait until the first OCI, but Terry, others, might advise differently.
Quote:
FWIW. Decided to go longer on the Factory Fill because when I checked the stick at 600 miles the oil looked super clean, like new. I made a blot sample. I then drove 400 miles this weekend, 95% mountain highway and got 35.4 MPG's! At 1K the oil STILL looks brand new, like zero miles and no oil consumption I can detect. I ordered LC tonight and think I will add some to this oil. The MM says the oil has 90% left and so I might go a K or two more. This engine seems to be breaking in very well. I'm reading about ARX...Is that really something I should think about using to clean the break-in metal out of the engine? Or will LC be all I need to do at this point?
Quote:
See what I mean...."it will clean up metal...in a brand new engine."
Quote:
Cicero:
What did your blot card look like?
Quote:
I remember distinctly on my dad's 2002 S10 4.3 Vortec. He bought it brand new... and @ 1,500 miles I changed the oil and the drain plug is magnetic from the factory.. had quite a bit of metal built up on it.
Quote:
Quote:
Quote:
Look. Its pretty simple to me. What is so special about the Honda Fill? I want the proof. The moly mixing thing is just plain silly. Don't most car engines have assembly lube in them from the factory?
Sure. Just not as much. Most of your factory fills for your Asian based engines have around 1000ppm of moly. Chevy ..100-300ppm.
So if I did an UOA at 500-1000 miles it will probably show X-1000ppm Moly?
