Quote:
Quote:
(...snip...)Please quote those service bulletins. Do they say it's special oil? (...snip...)
snip.
At TQI, does the factory-fill engine oil look less
like Texas Tea and more like Oklahoma Crude?
Don’t worry, there’s nothing wrong with the
engine. The engine oil looks that way because of
molybdenum (that’s “moly” for short), a special
lubricant applied by the factory to critical engine
components during assembly.
When the engine is test-run, that molybdenum
mixes with the engine oil, turning it a dark
metallic color often within the first 5 minutes of
running. And just how dark that engine oil gets
seems to vary between vehicle models, engine
types, and engine assembly plants.
What’s really important to remember here is this:
Don’t change the factory-fill engine oil because it
looks dark; just make sure it’s at the right fluid
level. To ensure proper engine break-in, the
factory-fill engine oil needs to remain in the
engine until the first scheduled maintenance
interval.
__________________________
There you go. You guys are unbelievable at times.
Ok. Here there it is. Where does it say anything about the moly mixing with the oil to make a special brew? That's your assumption. Maybe I should be impressed with you, some guy I never met who I have no idea what you know or don't over some guy that races Hondas at the dealership I will service my vehicle at and no one was challenging him with any service bulletins. Maybe you guys need to buy some assembly lube and add a bit of it to your oil to improve it. Your new additive trick perhaps?
I believe you are the ones dealing in assumptions and lack facts. Just because Honda says this doesn't make it so....EVEN IF TRUE...where's the beef? It it still goes back to my question, ah...speculation...that maybe all it is is an insurance policy for Honda that a customer doesn't put some garbage oil/wrong oil into the engine the critical first few thousand miles.
Now I'll ask you, since you want to wade in here, where is the proof that the oil is special or that Honda intends the Moly to mix in to the oil for special break in advantages?
At least one thing has ben proven to me. I got better replies by challenging your and other's "holy moly mantras" then I did asking a basic help and advice question in the first place or run the broken down search feature. The answers were all over the lot if you care to research that thread. Some criptic and funny, others not. I never got a concensus answer about the "break in oil". Perhaps BITOG needs a rating system that says...This guy knows his stuff, this guy does not. You can put me in the "does not know" column. I thought you mega-posters were the champs. Another bad assumption on my part. And the search engine still lacks horsepower. Maybe it needs some Moly.
