Nope. Not in the least! https://www.facebook.com/groups/1499093983993632I'm betting KTM addressed the cam/follower issue based on part numbers changing.
Not a Facebook member, so can't see any details. If they changed the part number per post 46, and they are still failing, then could be an oiling system problem or the manufacturing process (ie, materials, heat treat, etc) may still be a factor.Nope. Not in the least! https://www.facebook.com/groups/1499093983993632
Well, it is far, far more complex! So you have to join to find out or ... not.Not a Facebook member, so can't see any details. If they changed the part number per post 46, and they are still failing, then could be an oiling system problem or the manufacturing process (ie, materials, heat treat, etc) may still be a factor.
Aliens ?Well, it is far, far more complex! So you have to join to find out or ... not.
Of course! What else?Aliens ?![]()
How about a short summary of the real on-going cause of issue.Of course! What else?![]()
In summary: THe new wider followers made no difference. Although KTM says only earlier 790s are affected, that is NOT true. Cam failures are happening on ALL model years INCLUDING 2023 bikes. This issue is not fixed by a far shot and the jury is out on what that may hold for the new LC8c 990 engine.How about a short summary of the real on-going cause of issue.
So KTM, nor anyone else knows the root cause of the issue? Like I mentioned earlier, it's got to be an oiling issue or a materials/production issue or a combination. If KTM widened the followers to lower the load on the parts and if that's correct, then lack of lubrication or improper materials/heat treat is most likely the cause. Still possible it could be the load is still too high on the cam and followers, which would fall into the design realm.In summary: THe new wider followers made no difference. Although KTM says only earlier 790s are affected, that is NOT true. Cam failures are happening on ALL model years INCLUDING 2023 bikes. This issue is not fixed by a far shot and the jury is out on what that may hold for the new LC8c 990 engine.
Oiling has been suspected .. some have installed the stronger pressure relief spring raising oil pressure from 2 bar to 3 bar ... many reputable sources also believe the materials (DLC and insufficiently hardened steel) are to blame ... in short nobody has been conclusively able to say this is the reason. If you really want to follow and learn more, join that FB group. They're up to over 9000 subscribers.So KTM, nor anyone else knows the root cause of the issue? Like I mentioned earlier, it's got to be an oiling issue or a materials/production issue or a combination. If KTM widened the followers to lower the load on the parts and if that's correct, then lack of lubrication or improper materials/heat treat is most likely the cause. Still possible it could be the load is still too high on the cam and followers, which would fall into the design realm.
The cam eating issue looks like a lack of oil volume to certain areas of the valve train. That can be caused by many different and multiple factors. An increase in oil pressure when using the same viscosity would mean more volume is being sent through the oil passages. The oil pump performance and/or choked down oil passages would be the first suspects in causing a lack of oil volume to the required parts.There is alot of speculation that the oil pump simply doesn't create enough oil pressure for the oil passages it travels through.
In theory a thicker grade oil should create slightly more oil pressure than the factory spec of 10w-50 weight of oil.
I just always figured with KTM it was what they originally specified so they have just stuck with it for all bikes. No need to change. The reality is that most 10w-50s shear down to a 40w pretty quickly.There is alot of speculation that the oil pump simply doesn't create enough oil pressure for the oil passages it travels through.
Also, it's been said in the past that the closer the multi weight grade the better. Ex - 10w-30 vs say 10w-60 (yes it exists).
I do find value in a quality oil at a affordable price, but that is not the driving factor here. Bike takes 2.8 liters is all.
How is it on dead cold start up. I actually noticed slower cranking with the move from a 10w-50 to a 15w-50 last year. Nothing earth shattering but I was just wondering.I decided to try the Maxima Pro Plus+ in 20w50. (API SN rated)
It's only June and the majority of my ride yesterday was 85*+
Maybe this will help the KTM 'box of rocks' growl on startup.
