Help me decide what oil to use in new KTM
My favorite oils in order from most to less so are the following so far: HPL, Renewable Lubricant's Heavy Duty Diesel Oil Plus*, Maxima, Valvoline Full Synthetic**, the Mobil 1 mentioned already, and Motul 7100.
* I cannot recommend the Renewable Lubricant's to others fully, because it is not motorcycle specific and not having run it yet in my bike, I'm not sure how clutch friendly it is or isn't. I've run some non motorcycle specific oils in my bike though without issues. As long as they have decent amount of ZDDP with between low and moderate levels of moly and boron, they seem to be fine. The ZDDP levels in the R.L. oil is moderately high-about 1200 zinc and 1100 phosphorus.
** The nice thing about the Valvoline line is that they use from moderate to high amounts of GTL as the base. The 10w-40 in particular is very high percentage-between 80 to 90%. I think the 20w-50 is between 30 and 40%. GTL is a very nice base imo, and in some ways/areas competes with PAO's, AN's, and higher quality esters. With that said, a blend of the right PAO's, AN's, and/or higher quality Esters with a good additive pack can definitely outperform GTL with a good additive pack (in comes HPL's oils).
But here's the thing, relatively few motorcycle oils, especially OTS ones, use the highest quality bases + additive packs. You have to go boutique to get those i.e. HPL, Renewable Lubricants, Maxima, Redline, etc. and they are expensive. (Though, considering that you can run it at least twice as long with no issues, I would say that the HPL is cost effective, especially if you wait for the July 4th sale, use the BITOG15 code, and buy bulk).
Meanwhile, especially with added deals, the Valvoline products are quite reasonable, easy to source, etc. If I was in your shoes, I would consider doing half of Valvoline's 10w-40 Full Synthetic and half Valvoline's 20w-50 Full Synthetic (btw, the ZDDP levels in all 3 of their synthetic WCMO's are the same). That combo would give you 15w-45 viscosity range equivalent and with a higher GTL content than the pure 20w-50.
If I didn't have so much oil, that is what I would do with my bike in the warmest to hottest part of the season (run the half and half of Valvoline's Full Synthetic) sometimes. But I would still occasionally run the HPL and Renewable Lubricants for the very active cleaning. Now, if Valvoline ever puts their VRP chemistry in their motorcycle oil, I'd consider just running these, unless it was a particularly long and grueling trip (then right back to HPL and/or Renewable Lubricants).
I'm not sure how or why I left Amsoil off the above list, other than having a brain fart, but it should be in the above list either behind Renewable Lubricants or Maxima.
What a sad thread. Poor OP is doing all of this searching for a holy grail oil to try to keep his cams intact in the year 2025. I really want to love KTM, they make wicked road machines. That being said my personal experience with a brand new 390 duke, these issues and the fact they still want serious coin for their bikes it’s just sad.
Like subyroo mentioned, have you talked with HPL? They will literally work with you personally to find or make an oil for your situation. It’s one of the main reasons I spend my money with them. You won’t even see Amsoil do that.
And the 390 Duke is one of their more reliable bikes....
13k miles later, the cams look good. Most KTMs are actually a very good bargain compared to the competitors bikes. The 790 ADV is spec’d like a 14-15k bike for 10,900 USD which is a bargain IMO. The 1290 Super Adventure has everything a BMW GS has for $5-6k less. I don’t think they are overpriced at all.
I also can’t say they are unreliable, at least mine hasn’t been. I had a small countershaft seal leak due to running the chain too tight, other than that it’s just had maintenance. It’s been to the ocean on the west and east coasts and back to the Midwest and has always started and ran well.
I have no complaints and I may add a 24’ 1290 Super Adventure S to the garage if the sales on leftovers get any juicier.
Let’s talk oil!
I have a couple hundred miles on the new KTM 790 ADV already. I have two more weeks before I ride down to the tail of the dragon on a small trip. My plan is to get 600mi before then and do it’s first service before I leave on the trip. I’m not paying the dealer $370.00 to do the first service.
This is my first KTM so give me your thoughts.
KTM wants a 10w-50 MA2 oil to be used and Strongly Recommends Motorex. I’m not particularly sold on Motorex, especially given the cost at $22-23 a liter.
From my reading it seems in general KTM shared sumps are pretty hard on the oil and 10w-50 is pretty prone to shear.
I can get the following oils locally in towns I frequent. I can of course order anything online.
In 10w50 grade
Castrol 10w50 Power 1
Yamalube 10w50
Motorex 10w50
In 15w50 grade
Amsoil 15w50 Metric
Spectro 15w50 Platinum 4
Maxima 15w50
In 20w50 grade
M1 V-twin 20w50
Castrol power 1 20w50
Valvoline Synthetic 20w50
Originally my plan was to use the Castrol as its 10w50 and MA2 and will satisfy KTMs “warranty” requirements.
Have also considered using Amsoil 15w50 or even M1 20w50 V- twin as these will likely be more shear stable….maybe and it’s summer time.
Give me your thoughts!
The 20w50 valvoline syn, seen clutch slip issues in my 500, the Dino 20w50 DOESNT.
Since the dealer is doing, I guess your options is what they have.
Maxima has 2 full synthetics , the pro plus and the 4 extra, The pro plus, I found very decent, the 4 extra is more expensive. The 4 extra has a higher base ester oil, but both are ester oils, the 10w50's have the better flash points on both oils,
That is a Bold statement, at best to compare a KTM road/tour bike to a GS. I am not into the touring scene at all and even I know how legendary they are for reliability and their cult following.
Thing with KTM is they are pushing their motors to the limit, which will always show cracks in design and engineering faster than more tame machines.
Ducati V4 owner here. If I'm "reading the tea leaves", my choice of Motorex 15W-50 for a '22 Multistrada V4 PP wasn't a good choice <?> Well, at 9k miles, and nearing its 2nd 4k+ mile OCI (after the initial 600 miles with Shell 15W-50), I can't complain.
It shifts good (either w/clutch or Q/S), doesn't burn any oil between changes, and the top end is reasonably quiet (for Ducati's 1st go at a non-Desmo valvetrain).
It only calls out 10w50 and JASO MA2. No viscosity/temperature chart unfortunately.
Motul 5100 10W50 4T
Motul 7100 4T10W50
Motul 300V Off Road Racing 10W50
All are available at Ebay or Amazon for about $20 per liter. At least the first two. Amsoil 10W50 is at the same price too.
