He also tested a few home blended Xw-30 oils using a group 3 and PAO base along with 4 different VII. PAO/PIB resisted shear about as well as the no VII oil, but that stuff wrecked the oils winter rating.But also, mechanical shear (not sheer) of the VM is highly dependent on the engine. Most engines do not place high shear loads on the oil, but some might. In those results you posted, the no-VII result shows the margin of error for the test.
It would be neat to see the same oil run in different engines to see if there are viscosity differences. That gets to the question of how relatable is the KRL test? If I put Mobil 1 FS 5w-50 in my mustang how quickly would I see that amount of viscosity breakdown at the track or just from daily driving?
