Just did my first oil change on the car and there's a pretty big booboo in the owner's manual: it states a crankcase capacity of 4.4 qts when in fact it's 5.3. Honda's spec sheet on their website correctly lists 5.3, it's only the printed owner's manual that states 4.4 qts.
I had the car on ramps and put 4 qts in, thinking I'm nearly full, and started the car up and backed it off the ramps. After checking the level I thought I needed to let it settle a little. I left it on a level surface for over an hour and it still was well below the low mark (barely registering on the tip of the stick). So I slowly added til I got to just a tick over 5 qts, then started doing some research on Honda's website. I guess it's a typo
