Need pic of this Dicso era Country Club beast. Leasure suit not optional !
Did you check if it has a second drain plug as mentioned in another post? Some Ford products did. https://www.ford-trucks.com/forums/...hicles-came-with-two-oil-pan-drain-bolts.htmlMy dipstick is showing full with 4 quarts and this is the confusion of the whole thing.
Pic of oil pan?Pic of car?
I does not have 2 drain plugs.Did you check if it has a second drain plug as mentioned in another post? Some Ford products did. https://www.ford-trucks.com/forums/...hicles-came-with-two-oil-pan-drain-bolts.html
thank you,My feeling is you have the best and most accurate information of all the posts in this thread.For the past 40 years I've put 5 qts with a filter change in my 460 & 400 ci 1972 - 1979 Lincolns (2 72s, 2 78s, 2 79s)
The guy who's saying 6 qts probably has a later model year 460 pick up.
I mean the dipstick has not grown or shrunk in length to my knowledge and is the original and correct one for this engine/vehicle year.Do you know for certain the dip stick is accurate? The dipstick on my Jeep was off. There was even a TSB issued on it. It was replaced because it was a quart off. It happens.
Love that grill.
Thank you for reading my post. I also have a 1977 Grand Marquis with a 460 and it also uses 5 qts. I always used 10W30 with no problems.thank you,My feeling is you have the best and most accurate information of all the posts in this thread.
5 gallon jug of Amsoil 10w30Thank you for reading my post. I also have a 1977 Grand Marquis with a 460 and it also uses 5 qts. I always used 10W30 with no problems.
BTW did you use 4 single quart bottles or 1 large jug?
With my last 3 302 Fords had you put 5 quarts with a filter in one if them it would have been about 60% full. None of them would have been at full capacity. You do what you want.Sheeple.
My 5.0 demands 5 quarts with a new filter.
I'll put 6 in my 460.
Do what you want.
