And the pretendgineers here are still going on with the old “Honda isn’t what it used to be”.I believe Honda went with the displacement on demand setup after that year (or whatever they call it) in which the cylinders deactivate. I owned a 1999 Honda Accord with the 2.3 four cylinder Vtec, purchased new, kept it to 289,000 miles. There was no way in hell that engine was going to make it much further than 300,000 miles - that thing was consuming so much oil by the time I got rid of it (around a quart every 700 miles). Always highway driven and oil changes every 3,000 miles using conventional.
I must have replaced everything on that car at least once in that time, everything but the transmission and engine. I replaced the engine cradle, the gas tank, 4-5 sets of engine mounts, countless control arms and mufflers. Brake lines, fuel lines, EGR valve, evap canister (x2), Vtec solenoids, transmission switches, radio, axles, countless sway bar links and bushings, a power steering rack, a half dozen tie rod ends, a radiator, and probably a dozen other things I’m forgetting.
Yeah I was thinking the same thing, it didn’t look all that clean to me. However the burnt valve had most likely nothing to do with intervals, and the guy did make it to a million miles. Yet I agree, didn’t look all that clean in that intake, the heads had a lot of varnish. Still all this ^^^ is pretty normal for an engine with over 150,000 miles...you’re going to get varnish on a valve train in the rear head on a V6, and you’re going to get soot and carbon buildup inside an intake manifold.Engine is not very clean. If he had shortened the oci, it probably would be much cleaner.
Well, you might have just convinced me to adjust the valves on my daughters 2008 CRV. I did them once at around 100,000 miles, it’s now at 180,000 miles. The engine is very noisy, hear a lot of ticking. It does use a little oil between 5,000 mile intervals, maybe a half quart, maybe more. We’ve had the CRV for so long now - in that time it’s had some great maintenance, and at times it’s had some neglect. A month ago I realized it had gone 9,000 miles on Amalie 5W20 synthetic. It was a quart low too. This is what happens when you give a vehicle to your kids and have too many to take care of.Yet this happens to me on a 140k mile Honda. Burning oil, carbon held the valve open. I had adjusted the valves at 90k. The burnt one wasn't tight, had a piece of carbon holding it open. Oil changed every 5k. View attachment 168677View attachment 168678View attachment 168676
Not anymore they don’t. The manual I pulled for the new Type R civic from both the UK and Arab Emirates both show 0w-20 as recommended though they do show options for thicker oils. Toyota Land Cruiser from UAE also shows 0w-20 as “preferred” while listing others. Welcome to 2023Lastly, it’s hard for anyone to explain why thicker oils are recommended by auto engineers outside CAFE regulated USA. That alone speaks the loudest of all, not random stories.
I think it does prove something...that the TYPE of engine means quite a bit...and that group lll synthetics are all pretty good right now.It’s a fun topic but one anecdotal story is meaningless. It proves nothing.How so? What if someone had the exact same engine die at 175K with that exact same oil? No one would ever post that but I am sure it has happened. The oil would not be blamed, and everyone would suspect a one time manufacture defect. Lastly, it’s hard for anyone to explain why thicker oils are recommended by auto engineers outside CAFE regulated USA. That alone speaks the loudest of all, not random stories.
All part of the CAFE conspiracy to force lighter oil down your throat and cause engines to fail just outside of warranty.Not anymore they don’t. The manual I pulled for the new Type R civic from both the UK and Arab Emirates both show 0w-20 as recommended though they do show options for thicker oils. Toyota Land Cruiser from UAE also shows 0w-20 as “preferred” while listing others. Welcome to 2023
It’s been very well documented. There are others and even more when that particular engine was made.Not anymore they don’t. The manual I pulled for the new Type R civic from both the UK and Arab Emirates both show 0w-20 as recommended though they do show options for thicker oils. Toyota Land Cruiser from UAE also shows 0w-20 as “preferred” while listing others. Welcome to 2023
And those recommendations in the UK and Europe aren't made for a technical reason but a regulatory reason. This has also been explained multiple times but since it doesn't fit a specific narrative this reasoning is abandoned.It’s been very well documented. There are others and even more when that particular engine was made.
I agree with you.Basically all this thread is good for is saying a vehicle driven on the highway lots of miles a day will last a long time. A manual transmission, lack of DI, and other numb CAFE tricks will last a long time....
2023 Tacoma manual:Not anymore they don’t. The manual I pulled for the new Type R civic from both the UK and Arab Emirates both show 0w-20 as recommended though they do show options for thicker oils. Toyota Land Cruiser from UAE also shows 0w-20 as “preferred” while listing others. Welcome to 2023
That would require an OCI every 2 -3 weeks if he put the million miles on the car over 7 years, That is totally unnecessary.My guess is that the 6th cylinder's burnt valve wouldn't have happened at 920,000 miles or at all if he were doing 5k OCI.
None of the Honda international manuals I found show this, even in the UK. It just shows 0w-20 and Honda type 2.0 which is factory fill 0w-20.2023 Tacoma manual:
Which may be true, the fuel economy rules in the EU are similar to the US in regards to owner's manuals. Since the UK CO2 rules are modeled after the EU ones that isn't surprising.None of the Honda international manuals I found show this, even in the UK. It just shows 0w-20 and Honda type 2.0 which is factory fill 0w-20.
I can’t pull Toyota manuals on the computer I have now, but the ones that do give the option do it for high load and speed, which almost none of the thickies are achieving
That may be benefit enough for some people who still haven’t been shown any evidence of x20 being inadequate.Which may be true, the fuel economy rules in the EU are similar to the US in regards to owner's manuals. Since the UK CO2 rules are modeled after the EU ones that isn't surprising.
Still doesn't make it a technical reason however, which is what gets lost in this discussion. Besides a somewhat lower fuel consumption there are no benefits to lower viscosity oils.
My first car was an 86 Accord and the book spec for adjusting the valves was 15K miles. I did it dutifully many times.This story was discussed a few months ago. The owner is actually a recent "Bob" participant.
It seems likely that valve clearances were never adjusted, the exhaust valves got a bit tight and one burned. And thus the engine didn't make 1,000,000 miles "all in one piece".
In the case of Honda, more so than Toyota, they have promoted longer term plans for becoming more and more environmentally-friendly. If that means recommend 0W-20 oil globally because in the big, big, picture it does offer improved fuel economy (I didn't give a value and no one needs to nit-pick), so be it.Not anymore they don’t. The manual I pulled for the new Type R civic from both the UK and Arab Emirates both show 0w-20 as recommended though they do show options for thicker oils. Toyota Land Cruiser from UAE also shows 0w-20 as “preferred” while listing others. Welcome to 2023
