- Messages
- 1,937
- Location
- South Central PA (Fulton Co)
Didn't pin-stripes die off in the 90s? Who still wants those on a car?
I just received a roll of pinstripe for my 2021 Tacoma...
I'm an old soul apparently...
The key with those composite plastic housings is to lube the threads and the o ring, and look carefully at how the o ring makes the seal. On our '17 Wrangler with the Pentastar, the filter cap tightens till there is no gap between the housing and the cap, the o ring is between the sides of the cap and the inside of the housing, it does not have to be compressed like a regular style metal filter to make the seal. Just get it seated and snug, is all. Some people tighten these as if they were a traditional oil filter, but the way they seal is different.I agree. Whatever the spec is, the dealer grossly over-tightened it. I replaced with aluminum just to avoid any potential cracks or failures from the abuse, and because aluminum was available for the Tundra engine.
Composite isn’t, in itself, a bad design choice. I put new composite housings on my both of my 2002 Volvos in 2007, when I bought them. Oil change goons had used pump pliers on them and gouged them up.
Those composite filter housings look great over 14 years, and roughly 25 oil changes, later. Torqued to spec with a proper tool, composite housings work great. But they can be damaged by goons with a wrench.
Most of the time the breakage is because someone tightened it down too tight. On Toyota it is 18ft pounds or 25NM and the threads stay dry if you put something on the threads my guess is it would need to be less. I always advise to replace with metal. I myself have cracked my fair share of them so that way there is guaranteed to be no issues. Also people use the wrong tools on them all the time too causing breakage.The key with those composite plastic housings is to lube the threads and the o ring, and look carefully at how the o ring makes the seal. On our '17 Wrangler with the Pentastar, the filter cap tightens till there is no gap between the housing and the cap, the o ring is between the sides of the cap and the inside of the housing, it does not have to be compressed like a regular style metal filter to make the seal. Just get it seated and snug, is all. Some people tighten these as if they were a traditional oil filter, but the way they seal is different.
Yes I have heard about those. Definitely not simple like most.On the Chrysler ones its the same spec. 18 ft lbs but if you choke up on the ratchet you will feel when its seated and won't overtighten it. With delicate stuff I always use a short 3/8ths ratchet for tightening. If you crack one of these it's a big job because the oil filter housing is part of the oil cooler assembly and that can't be changed without removing both the lower and upper intake manifolds on the Pentastar.
Thanks bud! We’ve had a lot of fun driving the 4Runner around town, and on a couple of road trips to Memphis and N. IN.TL Did R.
Congratulations
Believe me, I agree with you.I'd dial back the A/T tires, Toyo makes the Open Country HT/2 (sweet) which makes alot more sense on your set-up.
Have these tires on Lexus with refurbished stock chrome rims and 20mm spacers, small 3/4" spacers give that subtleI'd dial back the A/T tires, Toyo makes the Open Country HT/2 (sweet) which makes alot more sense on your set-up.
