Disclaimer: Yes, I've spent time searching earlier posts...
What oils are good for cleaning up a motor? The 3.5L V6 in my Trooper has 75k miles and presumably lots of carbon buildup due to high oil consumption. I've always run 5W30 (went from dino to to synth blend to Mobil 1 Tri-Synth back to dino) which I'm sure hasn't helped the consumption.
I bought some Delvac 1300 15W40 tonight and plan to run it for 1,000 miles then change it out and possibly run it again.
Any suggestions?
OK, I'm new at this game and not getting any younger. As you can see, I don't even know how to quote a previous post yet. But anyway, I'm not quite done with this subject yet, so bare with me.
First of all, I must apologize for making some assumptions about this thread. When I first read Bluedevils post, I assumed that his excessive oil consumption was due to stuck ring packs and he wanted an oil to help clean that area of his engine. I also presumed that he wanted to do this to reduce his oil consumption. I must now assume that at 75k, his engine is just worn out and he needs an oil that will clean up the blowby etc. His engine is obviously going to use oil until it dies and no motor oil is going to reverse that trend. I did not mean to sound like I was flaming bludevils for his post in my last reply. This is a good thread from which I have learned quite a bit. Mostly I have learned to read more carefully. I have been guilty of applying my own circumstances to those of the original poster, and "hearing" the wrong information. My problem seems to be stuck rings on a '99 Cadillac STS, Northstar 4.6 w/ 42,000 mi. General consensus at the Cadillac forums, to which I recommend this site, seems to be that high oil consumption in this engine can be attributed to stuck rings. Cadillac has issued a TSB and devised a method of cleaning these ring packs up (with cleaners) without dissasembling the engine. If anyone on this forum would like to recommend a course of action which would duplicate this "cleanup" I would appreciate it greatly. Would anyone be willing to make a recommendation as to which oil to use in this engine to prevent this from happening to other Northstar owners? Further the moderator of those discussions is a Cadillac engineer (engine, I believe). He has stated many times that Mobil1 or other synthetics NOT be used in this engine. Could anyone tell me why that would be? Once again, I apologize for not listening and would like to thank all of you for the information on this board. John G
