Bluedevils, I'm going to preach here for a moment; move a little closer to the Monitor brothers and sisters. Close enough to place your hands on the monitor to feel the power of lubrication theory ! Uh, at least mine.
Motor Oils are designed to lubricate and safely disburse unfiltered contaminates for a design period of time. NOT clean microscopic layers of carbonacous deposits. If that oil chemically attempts to clean it will not lubricate and disburse properly resulting in poor lubrication function and increased wear.
Yes the high end group 5 oils and ester adds will clean for a while,due to the natural solvency of the esters. None of the others will clean to enough of an extent to make the difference that you are asking about.
Auto- RX does clean safely and effectively,and guarantees to be safe.
Note Frank Miller is sick with Cancer and is very knowledgable about RX but is not a mechanic or tribologist. Don't sweat his comments about syns as some here have, the Auto-Rx product works well.
Nuetra cleans but I have not tested it to confirm it ( I have a tremendous amount of respect for Bob Winters and Schaeffers to trust them on this, although I question its lubricity during cleaning),Molekule could answer questions as to the safety and effectiveness of the nuetra formula.
Lube Control will clean as it is a Bad *** solvent that is inhibited for lubricity and must be used systematically.
I was paid to test this like Auto-RX and have become more comfortable with its use while we continue to test it in field trial engines.
NO boys and girls I still don't "like" strong nasty solvents. This product is more of a stabilizer than a cleaner but can be used as a effective cleaner. It does have to be recharged every 1000 miles or so ( 1 to 2 oz.s) as the solvency degrades with use. This product has been hidden/shelved for years because the oil companies have no interest in eliminating oxidation making average oils last extended drains. Odis Beaver, Lube Controls owner is a lot like Frank Miller and is fighting to keep his product afloat.
Other products will clean and subsequently damage the metals and seals while cleaning.
These are three that may help you in finding that magic bullet to eliminate tearing down the engine to clean it.
Even a new low mileage engine that has been run on a synthetic oil will begin losing efficiency at the high temp/high heat areas that over time will build up and need to be cleaned to run as designed.
That mileage and time will be as variable as the operating conditions the engine experiences.
So I like the idea of periodically cleaning so my oil works as a lubricant not cooking off in a feeble attempt to clean.
Disclaimer; I don't sell any of these products but I trust them.
And now please place your hands on the monitor as we close with prayer.
