- Joined
- Dec 30, 2006
- Messages
- 29,558
I'm sure this has been mentioned here before, but when you change consistently with the exact same oil, does that keep the "oci wear" down (if my terminology makes any sense )?
So using the exact same oil with the same chemistry would be ideal?During a normal oci there's a phosphate film present, not so when you just rebuilt an engine. You want loads of phosphorous or moly right there right then to react to the extreme pressures and temperatures of metal on metal contact after rebuilding.
The old phosphate glass film gets stripped and replaced by the new chemistry alledgedly after each oil change
Yes. My point is once the engine is primed and running in the case of the new cam, the ZDDP and phosphorus are working, almost instantly. 20 minutes later change the oil, fill with fresh oil, there's still a film remaining, and as it gets depleted it is replenished.During a normal oci there's a phosphate film present, not so when you just rebuilt an engine. You want loads of phosphorous or moly right there right then to react to the extreme pressures and temperatures of metal on metal contact after rebuilding.
This is true, but many people who just swapped out a cam learned the hard way about using the proper break in oil and method. In 20 minutes or less a cam can be destroyed.rebuilt engine likely is tighter, it can be higher risk for metal welding. (without good amount additives)
The article is from 2007, oil has improved since then, and it goes on to say this: "These findings could be an enabler for achieving longer drain interval although several other factors must to be considered." That indicates to me there's more to it. So if you really want to get your OCI dialed in get a UOA. That's what I did, it was well worth the $10 I spent. Then there's the added value of knowing if your oil is staying in grade, your air filter is doing it's job, coolant is staying in the cooling system, you don't have a problem with a fuel injector/injectors, etc, and you're not wasting good oil.https://bobistheoilguy.com/forums/t...fresh-oil-break-in-period.286781/post-4801971
According to the paper mentioned it looks like the oils viscosity increased from a 20 to a thick 40 grade as the OCI went on. This is probably the only explanation that makes sense as to why it might reduce valve train wear and friction. It's fairly common knowledge around here that the KV100 viscosity has a large effect on valve train/timing chain wear.
If that's the case than perhaps we should all just be using a 40 grade whenever possible.
If this is true, my engine should be worn slap out!I was looking at a few BMW and Mercedes forums and some people say that short drain intervals will cause more wear because the antiwear additives need time to cling to the surfaces and are washed off with "too frequent" oil changes. I'm not advocating unnecessarily short OCIs but if there's proof that clean oil will cause more wear, i want to know about it, that is new to me. Would it be because different additives are temporarily working against each other if you switch brand/viscosity? I know a few people changing their oil every 5k km (3k miles) and and while i tell them to run it longer, they all have the healthiest never opened high mileage engines i know, some well over 500k km. Educate me because i am not gullible enough to believe that without proof.
Me too.True^^^. Same here.
Maybe a massive amount of ZDDP is necessary because there is no tribal layer to prevent excessive wear. The additional initial loading mitigates the lack of a tribal layer That may have otherwise formed given the right amount of time and heat.Yes. My point is once the engine is primed and running in the case of the new cam, the ZDDP and phosphorus are working, almost instantly. 20 minutes later change the oil, fill with fresh oil, there's still a film remaining, and as it gets depleted it is replenished.
FTR as I stated earlier I based my OCI on UOA reports. I'm not dumping good oil every 3k miles, and in my case good synthetic oil would never make the 10K miles so many here say it could in blanket statements.
Good point! But I will circle back to this statement in the article: "These findings could be an enabler for achieving longer drain interval although several other factors must to be considered." Operative words for me are several other factors. A lot plays into this.Maybe a massive amount of ZDDP is necessary because there is no tribal layer to prevent excessive wear. The additional initial loading mitigates the lack of a tribal layer That may have otherwise formed given the right amount of time and heat.
Since later discussions unable to prove that short OCI is harmful, why not enjoy new oil's smoothness?If this is true, my engine should be worn slap out!
