Album of finished project.
https://photos.app.goo.gl/pbiRtCvF5JCGGLiL7
I wanted to add a bypass canister filter. I chose a Ford 8N tractor for the part. Seller even sent me the metal lines, which with some bending actually fit. I prefer steel lines instead of rubber. Of course its harder to fit, but its more durable and saved me money. This Ford oil canister filter is from the early 1940's, amazing it still is in fine shape.
These canisters take a C3P cartridge filter, but since they redesigned and no longer make them as good bypass filters of 2 to 5 micron anymore, I setup this filter to use a roll of Toilet paper. If it is a tight fit then it filters well. TP filters send the oil up the center and oil flows out on the top, then percolates down and drains out the canister bottom.
I already am running the BD7317 venturi combo filter, and this one just will help clean the oil some more.
I shaped some aluminum plate to hold the filter and backed it up with a support so it wont shake itself to death and crack off due to vibration.
Oil drains back to engine through the secondary turbo oil drain block hole. Seemed silly to spend money, (rubber hoses and special fittings) and have it pump up to the oil cap, which would mean the cartridge would never drain completely when I go to change it.
