Antiseize on oil filter canister threads?
I am with others. No need for antiseize. Just make sure to change and lube the o-ring.
Wow!
Some people confuse spin-on canisters with cartridge filter housing caps?
Where do you see this? I don't see anyone confusing the two.
Question is, do you know what the Toyota canister filter housing looks like?
Wow! Some people confuse spin-on canisters with cartridge filter housing caps?
Yes :( I don't understand it either. Just one example:
As a side note, my Volvo XC90 5Cyl has a plastic canister and it works just fine.
The plastic canister on the newer Tacomas (I have a 2013 Tacoma 4 lt. with a spin on filter) seem to be extremely difficult to remove the first time but if you change your own oil you won't over torque it and future removals will go much easier.
The only plastic oil filter is the cartridge type where the inner element is replaced but the housing is reused.
Canister filters are always metal, they are self-contained and replaced as a unit.
I'm happy to know if I am wrong... please show me a canister oil filter made of plastic.
Not exactly wrong, just half right.
First of all for automotive applications there clearly two main types of oil filter units, both are canisters. One is the spin on, fully contained filter which some people happen to call "canister" or "oil filter"(perhaps a regional thing) and the other canister is obviously the removable cap and housing structure/body on the engine or mount. (Filter cartridge within formed canister). They both function essentially the same, the oil is captive within the canister as it flows through the filter element.
The canister is the can, not the filter element.
I just bring to snug. When I feel it bottom out, I'm done. 150k on one car, 80k on the other, both still have the plastic bit. I keep a metal housing around but just never got around to swapping in--figured I'd wait until it cracked. Still waiting...
Fair enough. My understanding of the two oil filter types was simply canister vs. cartridge.
Now we get to say "spin on, fully contained filter" vs "filter cartridge with formed canister." LOL :D Just kidding with you bruh.
I never cared for the term "spin on." Sounds like something a kindergartner would say.
Now we get to say "spin on, fully contained filter" vs "filter cartridge with formed canister." LOL :D ...
At least "spin-on" is unambiguous. If "cartridge" still has the original meaning to some people, while others apply it to cartridge filters, perhaps that term is best avoided to minimize confusion and misunderstandings.
I have seen people tighten everything to the point of deformation or stripping. I have never done it, stripped a bolt by over torque.
I dont like antiseize in anything to do with filters, reason is they use ground up metal particles, and that will get in the oil.
For example, a lot of add on diesel fuel filters such as CAT use aluminum threads, the filter base could have aluminum thread nipples, so when you tighten them up, it galls, and you can not remove the spin on filter, so the stupid people who stupidly use aluminum filters threads on aluminum filter bases, use antiseize, which gets into the diesel fuel going to the high pressure pump. When I put a tertiary fuel filter in front of the CP3 high pressure pump, I used a CAT filter with aluminum threads, but the filter base nipple is steel, so no need for antiseize. A LOT of add on diesel fuel filter kits used the wrong combination like I described, and only way to make their crap design work is antiseize, just dont even go there.
No need for anti-sieze on canister oil filter threads. But you should make sure the gasket from the old filter is gone, and wipe some fresh oil on the gasket before installing a new filter. Hand tighten, or go approx. 3/4 turn after the gasket contacts the base. Should be about the same.
The last two canister filter changes on my daughters Pontiac Sun Bird 03. The filters were crushed. Its sitting with 3 bent wheels. She hit a ladder on the highway.
