- Joined
- Sep 2, 2024
- Messages
- 58
I had a misfire code on cylinder 5, so I decided to start by first changing all the spark plugs (which it was time to anyway). I pull the spark plug for cylinder 5 and it looks like this:
Very bad right.. couple of other spark plugs also have oil on the threads but not as bad. It's only on the threads not the electrodes.
I also decide to swap the ignition coil with one in the front - #2 to see if that is the problem. The misfire code moves to cylinder 2 and cylinder 5 no longer has a code. This is telling me its the ignition coil. I change suspect ignition coil and the car is back to normal.
I'm not sure whether the oil on the threads was also contributing to the misfire, however the car is running now without any codes (with the new plugs).
The first time I changed the plugs on this car (that I bought brand new), some of the plugs already had oil on the threads. I suspect this car had a problem right off the line. The interesting thing is that many people with this same engine (Toyota 2GR-FE) have oil on the plug threads of the same exact cylinders. It seems it is a common problem with some Lexus/Toyota engines. I suspect that it is either, or both - the valve cover gasket or the spark plug tube gasket.
The question I have is: other cylinders were working fine without any codes while having oil on the spark plug threads. How bad is it considered to have oil on the Spark plug threads? Is a little bit to a moderate amount of oil not a big deal?
Another question I have is: is there an easy way to clean the oil off the spark plug threads on the engine side? Should I even bother doing it?
I'll come back to this thread in the afternoon to respond to replies. Thanks in advance.
