- Joined
- Jan 12, 2022
- Messages
- 20
I've got an unusual problem here.
This started with a Cylinder 2 misfire code on a 2003 Toyota Corolla. I decided to start the diagnosis by pulling the coil over plug and seeing if anything was amiss. When I pulled the coil out it took the spark plug with it. They were fused together and obviously the spark plug and stripped out of its threads and blown out.
I tried installing a new spark plug but it would not thread. Tried a thread chaser to clean up the threads, still no luck on the spark plug going in. Finally decided a Helicoil type insert was the next option. I went with the "Sav-a-thread" which is made by Stanley, Helicoil branded, and looks like a time sert. Followed the instructions, reaming it out with the tool, cleaning the gunk out of the Cylinder best I could with air, vacuum, and brake clean. Then installed with high temp RTV on the external threads of the insert as per the instructions. Let the RTV cure for 24 hours and installed the plug.
I also replaced the coil over plug that was damaged, and put new plugs in the other cylinders (hedging my bets here as I feared others might have been improperly installed like the one that failed and they were close to due anyway).
I then did a short test run, where it idled poorly for about 10 seconds before sounding more normal. Then today I did a longer test run driving around the lot. It seemed to start fine but rapidly returned to sounding and feeling like it was misfiring. Engine light flashed like it did before and I put it back in the garage.
Investigating the issue, I pulled the coils of cylinder 1 and 2. I checked the resistance between the spark plug wall and the cylinder head with a meter for both, they were comparable values. So I'm tentatively ruling out the RTV impeding a good electrical connection.
I then pulled the spark plug from the cylinder 2 hole with the insert in it. I expected to see some kind of damage to the plug, but it looked fine. The only thing I might say is it seemed to come out perhaps a bit easily, so wondering if it needed to be torqued more to stay in.
I'm at a bit of a loss here as I cannot see a reason for the persistence of the misfire. Does anyone have any thoughts on this?
