https://photos.app.goo.gl/pbiRtCvF5JCGGLiL7
Since they discontinued the bypass filters for the old housings, I decided fooey, I will make my own TP roll filter design. I bought a 1940's 8N oil canister, and figured out how to make this function. Oil comes up the center tube, and goes out the drain at the bottom, which this earlier canister did not have, had to drill and tap for a fitting. Some later models did have the drain.
I set this up to use a great value Walmart TP roll.
The double tube design, the inner tube holds down the outer sealing tube by way of the spring in the cover.
The inner SS screen is a cut off piece from a vegetable steamer, cost me 49 cents at thrift store. It need a bottom support for the TP filter so it wont collapse.
