Foam filled tires
If I had to guess, the fence post foam will turn to dust when it is flexed - if it flexes at all. If you're willing to clean everything, or buy a complete tire and wheel assembly, why not try it and let us know the result.
Yeah think so too. It looks like this is going to be a good mower. It has an hour meter on it and I'll see how many hours I get out of them before they no longer seem suitable for use.
Then I'll pay big $ for the real stuff.
It's met the goal of seeing if the mower mows. They started out holding sir for hours, put air in them, moved it. Now the worse of thee 2 tires held air for less than a minute. The other one isn't much better.
Maybe a de-thatcher hooked up to a Bob-Cat and really scratch into that dirt/grass. Be a bit time consuming,,,,or raise the grade a tad with some screened top soil in the most offending areas, then re-seed....Again time consuming though
I bought a used dethatcher in 2019 and it did almost nothing much to my surprise.
So much for that :( .....The CHEAPEST way out of this mess is to run the machine on some homemade metal rims. Like the REALLY old tractor rims. Will take a lot of time and fabricating, will need a welding machine. Use re-bar as wheel spokes,on the original rims, and some kind of pliable metal to make the wheel, and weld some nails to it for traction. Way out of my league on this crazy idea....but maybe another BITOG can help you. I don't know if you'll find solid rubber tires for this rider.
I got it. You can buy some galvanized steel garbage cans. Their round. And slice them up into 4" wide sections for the front, and like 16" sections for the rear, and weld the spokes/ rebar to the galvanized wheel part. Spot weld some short nails for traction, and spray paint em with black rustoleum. Yeah ! Sounds like a plan ! And you can aerate the lawn a little as you cut. Win Win !!! Now, the welding part . Do you weld ??? I don''t..... Maybe a BITOG guy can help you ? Maybe ? ( I'm not crazy am I....they did it on the old tractors )
That heavy v-twin has been rolling around on those tires for an hour and a half. Been sitting on those tires since Sunday.
No flat spotting an they're not turning to dust on the inside very much if any.
I don't get how can you create your own foam and still prevent the tire from going out of balance as your speed increase. It may not be uniform and it can easily spun around and shifting the weight inside, and never be able to balance it right.
Speed = maybe 5mph.
Therefore Ballance is irrelevant.
Quick, go " borrow" them !!!!! They won't be tough on the turf. You just can't go Nascar cutting grass, and make sure the traction nails are not too long.
3hrs so far and one of them seems like one wheel is getting some soft spots, the one that had my foam plug blow out on. Been sitting on foam for a week now.
I'm really liking the idea of front tires not going flat all the time. I'm going to buy some of the real rubberized flexible expanding foam ment for use in tires.
I'll put it on my 46'' 540cc mower first.
Eventually I'll beat the foam out of the 48'' 24hp mowers tires and do them up with super foam too.
I just put two no flats on the front of my Bad Boy Zero Turn this week . $80 buck a pair on Amazon .
Okay, I take back what I said about the tweel earlier.
Wow, they're expensive...
That's an understatement. I think their target market is people who want something that's different, just looks cool, or people looking to one up their neighbor with the same lawn mower. They look kinda neat but they're not $800 worth of cool.
Yeah I'm going for better than a tweel in probably every way for like 1/10th the price using that very high density urethane expanding foam.
Reoccurring tweel reviews in a nutshell:
"doesn't go flat"
"doesn't give a softer ride than pneumatic tires"
"not easier on the the lawn than turf saver tires"
IIRC, don’t they sell foam tires for OPE? If it was me before improvising with Great Stuff, I’d buy regular inner tubes and bike tubeless sealant like Stan’s or Orange Seal. No Slime. That stuff’s meh.
I put tubes in all 4 of my lawn mower tires, and they have worked for 3-4 years now. If your lawn is flattish and smooth, filling the back tires with hard foam would probably work ok. But if you need lots of traction or have a rougher lawn, you might want to mess around with tubing the rears as then you can run them softer for more grip or squish. My lawn with solid tires wouldn't work very well, due to bumps and traction needed for the slopes.
