AZjeff
$50 Site Donor 2023
That room is not accessible in a lot of stores right now.Just do it the old fashioned way and take them to the change room.![]()
Makes corduroy seem hip in comparison.Flannel lined jeans? What rock was I under when they were invented? Sounds worse then a Leisure Suit.![]()
I want to say they came from LL Bean … but had a couple pair where the inner liner (flannel) was too loose and would bunch up. By comparison some of the newer high tech long underwear actually got where even the thinner versions were amazing … slip and slide with pants.Just do it the old fashioned way and take them to the change room.![]()
Does anyone have a recommendation On a good flannel-lined jean? my waist size is about 37". Which means regular 36" jeans are almost too tight (Its what I wear daily now, though since jeans are 2" standards), but if I go 38" , they are usually loose in the waist, and I look like I pooped my pants. If I go with 36", the flannel liner will make it a 35". Should I go with a 38" and hope its sized down? and what brand?
I dont care what anyone says, There are cold days here in Arkansastan!!!Flannel-lined pants, or fleece-lined pants, may not make a lot of sense if you're in Southern Louisiana, or even in relatively mild D.C..
But when it's -20 outside, they sure are nice.
