4WD
$50 site donor 2025
I have never seen GM/AAM shed like Dana …I waited until 18k for the diffs. I probably should have done it sooner.
Color of the oil indicates nothing about its suitability for use.If it has synthetic in It I would change it at 5k miles or when it turns from yellow to very light brown which ever comes first
Yes it does tells you of the level of sludge and contamination it hasColor of the oil indicates nothing about its suitability for use.
F/U to his last video.
Welp! Science proved it - pack it up and let’s go home. Nothing more to see here folks.Interesting information. However, it bothers me that he, like so many people, says "Science" proves his point(s). Instead, the Data provided in the manner offered supports his thesis....but that's not the definition of Science. Science is a continually self-correcting approach referring to attempts to more completely understand and/or gain knowledge of a subject. Done rigorously, following the scientific method yields knowledge but doesn't claim to be wholly correct...although certainly not wholly incorrect. The misunderstanding of what following the process actually means is one of the reasons for the very common statement of "Science doesn't know everything", which too often yields the false conclusion of "Science doesn't know anything", which is what ignorant people too often settle upon as "the Truth", because they are then free to hold their biases as being True. Again, interesting data and thesis...but, that's not actually the definition of "Science".
No it doesn'tYes it does tells you of the level of sludge and contamination it has
The words coming from the mouths of HyunKia Inc and their Associates at dealerships must only be taken be taken with a grain of salt.kia told my father to come in at 5k for an inspection and tire rotation, told him see you at 10k for the oil change.![]()
Tells meYes it does tells you of the level of sludge and contamination it has
Tells me
The oil in there is doing its job. Take a gander at used diesel engine oil. You’ll be shocked![]()
Yes, 90% of your break-in is completed. Change the oil!I have almost 500 miles on my 3.6L Pentastar. Should I wait to change the oil or change it now? Does Jeep use a break in oil?
Absolutely!So I changed the oil at 500 miles. Currently have 1500 on the oil change. Now that the motor has 2,000 on it would it be good to do one more change to get any residual break in out then go to a 4 to 5k OCI thereafter?
