Buster,
What I'm simply saying is that you can't substitute 5w-20 for 5w-30 across the board in all engines. The results in my truck were very conclusive and I ran this test two times in a row. I actually expected to see the 5w-20 do just fine and I was very surprised. Well maybe shocked would be a better word.
For the Honda engines, the 0w-20/5w-20 grades both perform well, at least for newer engines with tight bearing clearances. It remains to be seen if this holds true for engines with > 150,000 miles on them. I think the book is still out on that.
The other reason why I don't like the 20wts is that the margin of safety is very low. For example, if you had significant fuel dilution due to a leaky injector, I believe you'd see very high bearing wear as a result. Using the slightly heavier 30wt oil simply gives you more of a cushion. I don't think using an ACEA A3 rated oil is absolutely necessary in a Honda engine, since they are designed to work with GF-4 rated 20wt and 30wt oils.
