Could you alter the cars resistance to air flow (the way the Americas cup yachts have special polymer coatings to make them more slippery) by say ionisong the skin of the vehicle with a charged particle effect such that you create a negative charge at the front and a positive ion charge at the rear - creating in effect a vacuum into which the car slips because of the positive charge at the rear pushing it and the reduced pressure in front pulling it!
This way you don't need a tractor trailer out front!
You use polasmoidal induction to achieve this effect!
First you would have to accept my postulate that indeed Albert Einstein was fundamentally WRONG when he suggested his Special theory of relativity!
Albert Einstein - a Nobel Prize winnner in Physics for his photoelectric effects paper!
Yet - no one remembers him for that, his legitimate claim to fame, instead today everyone remembers him for a non peer reviewed paper that somehow got published despite it's obvious basic & fundamental errors, that today any 14 year old kid could point out - if it werent for the fact they are indoctrinated at school with incorrect / flawed physics!
E=MC^2 is what Albert is famous for, Energy = Mass Times the Universal Constant C (speed of light) squared! The so called "theory of relativity"!
Everyone knows this yet, it is patently WRONG, and easily disprovable!
Here I'll do it for you - just so you don't think I'm pulling your leg!
If I ask you the square root of 4 - most of you here would answer 2
You'd be correct!
A FEW 14 year olds who'd just compeleted a certain level of mathematics tuition however, would give two asnwers!
Square root of 4 = 2 and (negative) -2
Thats right, the negative root squared, equals a positive result!
-2 x -2 = +4
Most of us forget that bit!
Guess what - so did Albert Einstein! (And almost everyone whos come after him!).
E = MC^2
Speed of light C (in a vacuum) used to be considered roughly 186000miles per second
These days of metrics it's expressed as 3 x 10^8 meters / second
When we square it we get 9 x 10^16 meters/second & thats the value of C squared!
Only one little "overlooked" problem with Albert E's much vaunted relativity theory!
-3 x 10^8 squared ALSO = 9 x 10^16!
Yes - the speed of light in Albert Einsteins FAMOUS THEORY OF RELATIVITY theorem can be both positive (travelling in one direction) or negative (travelling in the opposite direction) AT THE SAME TIME and STILL make his theorem true!
Don't try that at home folks (going in two opposite directions at the same time) unless you want to rip yoursleves a new butt hole!
So, what can we infer from this conundrum?
The usual problem with producing a hypothesis based on a "false" premise is a paradoxical result.
For example:-
(1) All dogs have four legs,
(2) All four legged animals are cats.
Therefore:
All dogs are cats,
AND/OR
All cats are dogs!
Which premise is false?
With the Special Theory of Relativity, the resulting paradox, was called the "twin paradox" along with several others which were discovered later.
So - the point of all this? We really do NOT yet fuly understand science and physics as well as we believe!
I'll give you another special theory of relativity!
Quote:
Never Loan Munney to Relatives!
Plasmoidal induction - and the speed of light equals infinity (the ONLY value for C that makes Albert E's forumla true!).
So much yet to learn hey!
Cheers!
