Hermann
Site Donor 2023
No biggie either way.
So struts/springs better... but you still have essentially a prop rod as your fail-safe when the strut fails on you?
Why not use a true lubricant?The hinges get rusty and fight you until one folds sideways... that's a fun day. Be sure to hit them with WD-40 before that happens.
How about trunk struts? Since 2 of my cars have them, one German and one Japanese, I think it was a sign of the times, as they are 2007 and 2006 respectively. To me, it makes the trunk lid heavier and more easily slammed, a disadvantage. BUT, I thought the trade off was there really isn't any intrusion into the trunk space, so more usable cargo area....Why not use a true lubricant?
Some vehicles with springs are known to bend the hood if you let the hinges get too rusty.
Likely cost to manufacture: spring > strut > rod
Weight: springs> struts > rods
I once had this idea, what if in addition to the soft close door, a hologram of a hand wearing a white glove, appeared near the handle, creating the illusion of a butler closing the door. I was going to go on Shark Tank but chickened out....With the decline of sedans being made trunk struts are a rare thing now.
Now soft closing doors, that’s a sign of luxury or laziness.
The TSX is like most Hondas; 2 hole positions and one prop rod on the passenger side. It is not in the way for anything I have done. The TSX is bigger than a Civic; the K24 is kinda tight. I hate changing the rear mounted oil filter.And on that TSX, is there a twin rod on the other side of the compartment, so when changing the belts (darn, there's that replacement thing again) it doesn't get in the way, even if just a little? Now, where's my patent lawyer's phone number…
