Originally Posted By: fdcg27
Really?
Synthetic oils have "exceptional wear reduction properties"?
Stick around here for a bit, and you'll see how silly that seems.
Better yet, check the used oil analysis forum right now, and observe for yourself that there is nothing noteworthy about wear reduction with any synthetic oil.
Perhaps I should have phrased that differently.
Synthetic oils have more ability to resist wear than a typical dino.
They do?
I'm not sure how you'd phrase it, but on typical 5-6K drains, typical dinos show wear numbers as good as or better than any syn.
Check out the used oil analysis forum for yourself.
There are only three reasons to use synthetic oil.
If you want to.
If you want to extend drains.
If your engine requires it.
There is no reason to believe that synthetic oils have more ability to resist wear than do dinos.
I use syns because I want to.
No engine I've ever used syn oil in has required it, and that is true for most users.
Many manufacturers build turbocharged gasoline engines and say conventional is okay, but using synthetic delivers far better results.
