There is a 507.00 I added it sorry. There are not many options but I would still use one of the Mobil's over Penrite.Not approved for VW 506.01.
"should be OK" yes. You could certainly try a different oil though.Got it. I'm not usually conned by language.
With that much zinc and boron it should be ok though, right?
Same - try the Liquimoly Engine Flush. Nothing to loose but $10 US.Flush it with liqui moly engine detox run a short interval and do it again. You can get it from Supercheap or Autobarn. You dont need to do piston soaks and what not.
It sounds like your 2005 Touareg R5 TDI is experiencing some blowby smoke, which can be caused by a variety of issues such as worn rings, cylinder walls, or valves. To address this issue, you may want to consider using a product that is specifically designed to decarbonize the oil rings and help restore engine performance. There are a number of different products on the market that claim to do this, but it can be difficult to know which ones are effective and safe to use.2005 Touareg R5 TDI.
I've got some blowby smoke, rebuilding the turbo didn't reduce it as much as hoped.
I want to decarbonise the oil rings, does anyone have a suggestion as to what the best product would be.
One thing I'm a bit nervous about is the Nikasil bore lining.
It's done 295,000 kms and there's no sludge or varnish in the oil.
Great info, however I wouldn't consult a/my mechanic regarding the bore lining, too risky. I'd seek that info elsewhere.It sounds like your 2005 Touareg R5 TDI is experiencing some blowby smoke, which can be caused by a variety of issues such as worn rings, cylinder walls, or valves. To address this issue, you may want to consider using a product that is specifically designed to decarbonize the oil rings and help restore engine performance. There are a number of different products on the market that claim to do this, but it can be difficult to know which ones are effective and safe to use.
One option you may want to consider is a product that contains a combination of cleaning agents and lubricants to help break up and remove carbon deposits from the oil rings and other engine components. These types of products are often applied through the engine's oil system and are designed to be used in conjunction with a normal oil change. It is important to follow the manufacturer's instructions carefully when using these types of products, as using too much or using them improperly can potentially cause damage to the engine.
In terms of your concerns about the Nikasil bore lining, it is important to keep in mind that the Nikasil process is a specialized method of coating the cylinders in an engine with a thin layer of nickel silicon carbide. This type of coating is known for its durability and wear resistance, but it can be damaged by certain types of oil or additives. If you are using a product to decarbonize the oil rings in your engine, it is important to make sure that it is compatible with the Nikasil bore lining and will not cause any damage. You may want to consult with a mechanic or the product manufacturer to determine if the product you are considering using is safe for use in an engine with a Nikasil bore lining.
This engine the R5 TDI PD engine has plasma coated bores not Nikasil, the older R5 TDI CR engine is an iron block.It sounds like your 2005 Touareg R5 TDI is experiencing some blowby smoke, which can be caused by a variety of issues such as worn rings, cylinder walls, or valves. To address this issue, you may want to consider using a product that is specifically designed to decarbonize the oil rings and help restore engine performance. There are a number of different products on the market that claim to do this, but it can be difficult to know which ones are effective and safe to use.
I don't disagree that there might be something better but it does work pretty good and there is always a bottle laying around the garage somewhere. I run it in everything , 4 Wheeler, mowers, and both my vehicles. Lubes the fuel injectors pretty good too. I would highly recommend it for anyone with a sticking injector.Search the forum, ATF as a engine cleaner has been beaten to death. FTR our resident industry experts chimed in, there are much, much better choices.
I beg to differ, there are better choices, much better. Search the archives, or ask an expert if you don't believe me.I don't disagree that there might be something better but it does work pretty good and there is always a bottle laying around the garage somewhere. I run it in everything , 4 Wheeler, mowers, and both my vehicles. Lubes the fuel injectors pretty good too. I would highly recommend it for anyone with a sticking injector.
Pretty sure I was agreeing with you when I said "I don't disagree"I beg to differ, there are better choices, much better. Search the archives, or ask an expert if you don't believe me.
Some think MMO is Type-F. Regardless, I've used it in hot-soak cleaning along with Seafoam for great results in a 50 yo 413. Run it hot, pour it in at idle and kill it a second later, every time I drove. Repeated ~5 times.Search the forum, ATF as a engine cleaner has been beaten to death. FTR our resident industry experts chimed in, there are much, much better choices.
Some think a lot of things here.Some think MMO is Type-F. Regardless, I've used it in hot-soak cleaning along with Seafoam for great results in a 50 yo 413. Run it hot, pour it in at idle and kill it a second later, every time I drove. Repeated ~5 times.
Snake cam in a plug hole (intake was just as clean):
I'll look into the Rislone. Is it the idle for 10 minutes type or do you leave it in?Or a couple of short (2K mile) OCI's using M1 High Mileage synthetic oil ?
So....I got a response to your question. I actually had this on my mind for some time, did some reading,etc and here goes. Apparently the original Rislone has been around for a long time from what I was told with customer service. If you use the HM Concentrate it will supposedly do a very slow version of what the EC30/40 from @High Performance Lubricants does. I was looking to something similar in my case. It was explained that a flush might remove things too aggressively and that using a few bottles on a few standard 4-5k mi oci would get you some results. I also got the answer that doing other practices to hit it from all possible angles would be a great way to go after the leviathan from using TT fuel with pea additive and topside cleaning of throttle / valves. I did this exact same thing with a case of LM Hydraulic Lifter Additive and all other means and got my consumption down to where fuel dilution and lead foot doesn't consume nearly the oil now. More than one way to skin a cat. Could do the EC30, could do it the way I described, could use something from HPL,Redline,etc that has a known ester content that's up for the job.How about Rislone High Milage Concentrate (16 oz.) added to the oil ? ... Or a couple of short (2K mile) OCI's using M1 High Mileage synthetic oil ?
Two bottles of the concentrate run it for 100 miles, then change the oil and filter. Refill with fresh oil, a new filter and one bottle of the concentrate. Run it for a 4K-5K OCI. From what I was told that should clean things up nicely according to a very well known Bitog buddy of mine. It did silence a lifter tick in my brother's iron duke boat engine, it's still silent a few years later.How about Rislone High Milage Concentrate (16 oz.) added to the oil ? ... Or a couple of short (2K mile) OCI's using M1 High Mileage synthetic oil ?
Another product is hot shot stiction eliminator.....2005 Touareg R5 TDI.
