Dad's 1947 Lincoln coupe
Today, got the hazard flasher put back together and reconnected. Got it back in place, and noticed that the driver's side courtesy light was out again. Darn thing has been driving me up the wall as it comes and goes. Found out the bullet connector that goes over the hazard switch was being flaky. Got it replaced, put it back together, and that's when I found the frayed spot on the wire the hard way. It bumped the body of the hazard switch and SPARK! Yikes! No damage, thankfully. Got some heat shrink tubing on that section of wire, and got it lashed out of the way. Now the courtesy light is working reliably, the hazard flasher is working, and I got the aftermarket reverse lights working again.
I've got the new wires bundled into the loom material, and almost got them routed into place. One of the screws for the clips that holds the harness in place was also the screw that held the coolant recovery tank in place. That's another one of dad's modifications, it didn't have one originally, the coolant overflow just discharged onto the road. The inside of this tank was pretty messy, and I couldn't see the coolant level. Surprisingly, toilet bowl cleaner and a bottle brush works quite well for cleaning these things. Seems wire handled bottle brushes are a thing of the past, because I needed to bend it to reach it all. That's OK, the plastic handled ones bend pretty easily if you heat them over a heat gun.
It was a long and storied journey, but my dad's 1947 Lincoln is finally home. Dad had it since college, and he was the third owner. The odometer has rolled over twice (!) since he's had it. He retired out in Arizona about 15 years ago, and he had worked on trying to get it roadworthy again as it had been dormant for a while. Unfortunately, he had some significant health issues crop up last year, and my sisters asked me to take the car since it looks like mom and dad will be moving into assisted living soon. Looks like I have some work ahead of me. It's got some electrical problems, a weak starter, non-functional power windows, and the paint is not great. On the plus side, he did finish putting a new clutch in it, replaced a worn out final drive bearing in the transmission, replaced the brake lines, overhauled the brakes, and it has new radiator and heater hoses. Also have several boxes of spare parts for it.
After an aborted attempt to tow it cross country with a U-Haul car carrier, I left it to the pros and they delivered it this morning. Mom, Dad, and my sisters are glad it arrived safely, and hopefully I'll have it roadworthy again soon.
Some deets:
1947 Lincoln model 76H coupe
292 cubic inch (4.8l) V-12 engine
3 speed manual transmission with electric overdrive
Power windows
Remote control AM radio
Electric clock
Trip odometer
Do you know how many. miles were on it when your dad picked it up? Original block and engine? A guy that used to ferry passengers from my local Nissan dealership was a hoot. Walt said his dad had a Hudson that the engine was shot at 40k miles and he helped his dad rebuild it on the shop workbench.
The wiring harness came out nicely, and it looks nice. Got it all routed and tucked away, and it's all working.
Just when I thought things were progressing along, Murphy had to throw a wrench into things. The right side water pump (there are two) decided to let go. It's dripping coolant at a pretty good rate. The left side probably isn't far behind, it's very wet.
Fortunately, there's a guy who specializes in rebuilding them. I could buy a kit and do it myself, but I'm not confident in my ability. I reached out to him, and his price is pretty reasonable. Took me 3 hours, and the service manual doesn't mention that you pretty much have to take the distributor off first. The water pumps are off, they are reasonably degreased, and the rebuilder is ready for them. Guess while he's rebuilding them, it's a good time to revisit the window pump.
Not sure how many miles when dad got it, but he thinks it may have rolled over once before got it. It has rolled over once he's owned it. It's either got 130,000 or 230,000 miles on it now. Not the original block though, he had a parts car and rebuilt the engine from that one. The original engine is in pieces in the back of my garage.
No news on the water pumps yet, but it's only been a little over a week, and the guy was projecting 3 weeks to rebuild them. I got back to the window pump, and the first surprise was while it was sitting in the trunk, it didn't take long for the relief valve to get stuck again, necessitating some penetrating oil and getting it to move freely again. I bought a new solenoid, and now it runs without the terminals getting hot. However, still no fluid coming out of the outlet. Called up Hydro-e-lectric, and looks like I'll be shipping it off to their experts to give it a clean bill of health.
Really eager to drive it for the first time, especially now that it has working lights again. Oh well, Hydro-e-lectric says it's only about a 1 week turnaround on the window pump, so if I get it off to them this week, maybe I'll have rebuilt water pumps arriving about the same time.
Getting closer to that light at the end of the tunnel. After 3 weeks in capable hands, the water pumps have been rebuilt, and they look brand new! Big shout out to Skip Haney in Punta Gorda, Florida who specializes in vintage Ford water pumps, distributors and coils. Water pumps are back in, and replaced a bunch of old hose clamps. The hoses are new, thankfully. Picked up 7 gallons of coolant, since the stated capacity is 27 quarts, and I certainly got more than 6 gallons out it when I was draining it. Got it refilled, got the distributor back in, and the engine fired right up. Knock on wood, just one small leak from a loose hose clamp, but looks like all the coolant leaks are fixed.
In other developments, the power window pump is kaput. I sent it out Hydro-e-lectric, and they concur, it's beyond repair. They couldn't get more than half the rated pressure out of it, so it was not going to work. So, plan B is they have a new design pump to replace the old one. Looks a little different from the original, but it mounts and works the same. They knocked a little off the price since I let them keep the old one as a core, but a brand new pump is on the way and should be here any day now.
Wow! If the internals of the water pumps have been given anywhere near the detail that the exterior has, you should be in great shape for the cooling system.
I've seen specialty rebuilt parts for exotic cars before, and they don't look like they got near the attention that those pumps did.
Lots of progress today. I had one leaky hose clamp at the radiator that I replaced and tightened up. That one was a pain, it's near the fan and it's in a tight spot being next to the radiator. Then, I had bought new spark plugs for it a while back, and it dawned on me they were still sitting on the passenger seat. Looking at the old ones, they had definitely seen better days. I remember it must have been around 1985 when I helped dad replace them.
Once I confirmed the coolant leaks were fixed and the the spark plugs were regapped (ugh, regapping 12 spark plugs stinks), I decided that it might be time for a drive, finally. I can say that the last time I know for sure it was driven was probably 1996. Finally, after more than a year of tinkering in my garage, It made a short drive and back, but I see it's going to need a few things yet. It was hesitating badly on acceleration, so I'm wondering if I have a vacuum leak or the distributor advance is flaky. Also heard a squeal from the belt, so I guess I need to tighten the belt a little more. On the plus side, it rides nice, the engine sounds smooth, temperature stayed normal, clutch and drivetrain sound fine.
