Also here are a few previous discussions on this apparently popular topic. You even participated in at least one:
This engine needs 10 qts, and I'm going to dump it at 5K anyway, so I'm a little hesitant to jump on to the HPL bandwagon.
I'm not worried. I'm hesitant to jump to the most expensive option before ruling out more accessible and less expensive options.
If I knew it were a guaranteed fix, I'd do it. I don't see evidence of that.
The Hemi guys swear by Red Line 5w30. I run it as well and it makes my B58 not sound like a little tractor anymoreI've done 2 (short interval) oil changes on m Mustang. The tick popped up slight after the first and it's louder with the second. I drive next to concrete or brick walls pretty often, where it's most noticable, and it bugs me.
I'm using Kirkland 5w-30 right now, I'm only 100 miles in to this change, but I'm going to dump it. Yes, it bugs me that much.
What is a good next one to try? I'm considering:
Valvoline EP 5w-30
ESP .... 0w or 5w?
I really want to avoid Ceretec as a fix.
Yeah I think a lot of people confuse bottom end tick with the injectors, then there’s also the awful sounding 2k rattle. It’s a noisy engine in a lot of good ways and bad ways.My son had a 5.0 Mustang with that ticking. I listened to it and it seemed (to my ear) to come from the fuel injectors.
Or an oil like hpl that has no official certification. I recommended Hps and it’s the same way. I believe schaeffers is approved, it’s at least dexos and SP compliant. I did use hpl in my new 2024 for a few oil changes and am now running torco SR1 and neither of those are official SP oils. I like to live on the wild side.I wouldn’t be playing around with extended OCIs under warranty either. Plenty of time for that later.
M1 0/40This engine needs 10 qts, and I'm going to dump it at 5K anyway, so I'm a little hesitant to jump on to the HPL bandwagon.
