I have a 2016 F-150 2nd Generation 5.0 Coyote with 68k miles.
I've regularly changed the oil between 4-5k with Motorcraft 5w20 Synthetic Blend, per the Form manual. Never an issue and the engine has always sounded good and fairly quiet.
At 65k miles, I started to hear a flutter or a tick in the engine compartment.
One dealer said the noise was normal. It was a new noise for my truck, so to me I don't consider a new noise normal.
Another dealer said it was the water pump and tensioner pulleys and replaced both, and both belts. .
Checked manifold for leak. All good.
Did compression test. All good.
Not Cam Phaser, as I know what that sounds like and neither Dealer thought it was that, either. Plus that's typical (moreso) on Ecoboost models.
The noise is still there. I've read a TON about the Coyote tick and think that's what I have.
I recently changed the oil to 5w30. I've read that 3rd Gen Coyote's are now recommended 5w30, and Ford has acknowledged the tick but says (of course) it's normal. Maybe it is normal, but I never used to have a 'tick.' The 5w30 has quieted it a little bit, but it's still there. Just on idle. Never gets louder on acceleration or otherwise. Also, sometimes it 'goes way' after driving for a while, but sometimes it's still there after I park / get out and listen to engine.
I'm considering either A) adding in LiquiMoly Certec, or B) going to 5w40 (Rotella T6, Castrol, or Mobil 1). I've read stories of folks trying those options, with success.
Wondering if anyone has any similar experiences and perspectives on what worked to solve their 'tick' if they've had it.
Thank you.
Thank you.
