Random QC testing is different.Actually, API does test oil. In order to maintain the license, API will at random test oil to ensure it still meets the requirements of the API specification(s) the license is for.
My BMW's manual does not allow for oils meeting the LL-01 spec - only LL-01 FE or LL-17 FE+. So Pennzoil is not in the game, unfortunately. But thanks for the suggestion.API isn't the be all end all in the Euro world. You either trust the tests behind the automaker specific Oil Cert or you don't.
Mercedes Benz, who's also not on the list, has their own timing chain and LSPI test.
I have no idea how these OE tests compare to those found under SN+ or SP but I know for a fact that they exist.
Oil blenders have a wider customer base so there's a financial incentive for them to obtain API licenses (Ex Liqui Moly, BP (aka Castrol)) for a variety of their products.
If you're so hung up on API SP oil then buy Pennzoil Euro 5w40 with LL01.
That is fine. However, you will also be fine with extended-performance API-SP oils such as Castrol EP 0W-20 SP or 5W-30 SP or Mobil 1 EP 0W-20 SP or 5W-30 SP. Valvoline EP 0W-20 SP or 5W-30 SP should be fine, too.My BMW's manual does not allow for oils meeting the LL-01 spec - only LL-01 FE or LL-17 FE+. So Pennzoil is not in the game, unfortunately. But thanks for the suggestion.
So, my conclusion is that at least for recent model BMWs, the set of oils meeting @Gokhan qualification of "if a legacy ACEA oil also carries an API-SP approval" is empty. So we will continue to be unable to "ensure that [any oil] will provide the highest valvetrain wear, timing-chain wear, and LSPI protection".
Disappointing, to say the least.
Ya well the B48 can run LL01, LL04, LL01FE, LL12FE and LL17FE+. LL01 FE is a "fuel efficient" version of LL01 as the HTHS is slightly lower.My BMW's manual does not allow for oils meeting the LL-01 spec - only LL-01 FE or LL-17 FE+. So Pennzoil is not in the game, unfortunately. But thanks for the suggestion.
Thanks.Ya well the B48 can run LL01, LL04, LL01FE, LL12FE and LL17FE+. LL01 FE is a "fuel efficient" version of LL01 as the HTHS is slightly lower.
Automakers have been very sensitive to the regulatory schemes (Emissions and FE requirement such as CAFE). They're not going to recommend an oil which is thicker than the one used to certify the drivetrain. Beginning around 2016 BMW moved their North American fleet to LL01FE and then to Xw-20 with the B-series engines.
Edit: Here's some more info. BTW..Just to make clear I'm not judging you at all. You can pretty much run almost any oil in the B48 and if you want to run a euro-centric SP by all means go for it.
IIRC it's around 2018/2019 but as you can see it mentions engines with and without GPF so you can get an idea of how recent it is. I do know it's prior to the time that the US moved to ULSG (circa 2020).Thanks.
I have seen this chart before and wondered what the publication date was. Is it recent? Is the context for the US or some other part of the world?
LL-01, LL-04, and LL-12 FE are not among the recommended oils in my 2019 US B48 manual. BMW may have changed their mind about those oils between the time this chart was published, and my car's manual was published, at least for the US.
It's compliance testing to by API to ensure the license is valid.Random QC testing is different.
(All temperatures are in celsius) | Castrol Edge Extended Performance 0W-20 C6 | Castrol Edge 0W20 LL17 FE+ | Genuine BMW TBT 0W30 LL-01 FE | Genuine BMW TBT 0W20 LL-17 FE+ |
cST@100C | 8.2 | 8.18 | 9.92 | 7.8 |
PP | -42 | -42 | ||
Flash | 203 | 221 | ||
VI | 166 | 169 | ||
CCS | 5800 | 5580 | ||
Ca | 953 | 976 | 1289 | |
Mg | 741 | 836 | 540 | |
Na | 11 | |||
P | 741 | 643 | 735 | |
Zn | 817 | 750 | 817 | |
Moly | 71 | 75 | 85 | |
Ti | 23 | 17 | ||
Boron | 138 | 150 | 114 | |
HTHS | >= 2.6 | 3 | >=2.65 | |
API | SP | SP | SP | SN |
ILSAC | GF-6 | |||
ACEA | C6 | C5 | A5/B5 | C5-16 |
MB | 229.71 | |||
GM | dexos1 Gen 3 | |||
BMW | LL-17 FE+ | LL-01 FE | LL-17 FE+ |
Oops, I screwed up. The UOA derived values under Castrol Edge Extended Performance 0W-20 C6 are not for that oil but for Castrol Edge 0W-20 SN. Treat with skepticism rows 7-16 in that column.Here is an interesting comparison that I put together of 4 current Castrol products using the most recent data available. The first three are very similar. With the exception of the higher weight for the third product, are the first three products actually the same product or slight variations of the same chemistry? The fourth product is clearly different, but perhaps will evolve in the direction of the other products?
(All temperatures are in celsius) Castrol Edge Extended Performance 0W-20 C6 Castrol Edge 0W20 LL17 FE+ Genuine BMW TBT 0W30 LL-01 FE Genuine BMW TBT 0W20 LL-17 FE+ cST@100C 8.2 8.18 9.92 7.8 PP -42 -42 Flash 203 221 VI 166 169 CCS 5800 5580 Ca 953 976 1289 Mg 741 836 540 Na 11 P 741 643 735 Zn 817 750 817 Moly 71 75 85 Ti 23 17 Boron 138 150 114 HTHS >= 2.6 3 >=2.65 API SP SP SP SN ILSAC GF-6 ACEA C6 C5 A5/B5 C5-16 MB 229.71 GM dexos1 Gen 3 BMW LL-17 FE+ LL-01 FE LL-17 FE+
ACEA A5/B5 doesn't have a LSPI or GDI chain wear test.I just stumbled on this. Are there many oils available with these new ACEA ratings? I was considering an A5 rated oil per Hyundai’s manual but if SP is really ahead of things in timing chain wear I will probably just keep it simple and use readily available SP full synthetic. This also makes me think twice about M1 0W40 in my ecoboost.
EDIT: Mercedes Benz has a LSPI test.ACEA A5/B5 doesn't have a LSPI or GDI chain wear test.
ACEA A7/B7 do have LSPI and GDI chain wear test. In fact, it's the same tests which are used for API SP. Source: 2021 ACEA Test Sequences
Think of A5 as SN and A7 as SP.
However, euro certs have had their own timing chain wear tests which are conducted on on GDI engines. I don't know if they also have LSPI tests.
