TPT= twin power turbo bmw.What is TPT?
in Europe you can find it in market ,online shops, for 13 euros just like in the US.at stealerships costs around 28.
Is BMW TPT in EU now Castrol or is it atill Shell?TPT= twin power turbo bmw.
they told me that new deal with castrol will begin from new year.they were discussing with another supplier for europe than castrol ,nobody knows whom,but ended up with castrol again.its still shell until the end of the year.Is BMW TPT in EU now Castrol or is it atill Shell?
I mentioned this in 0W40 section, but this oil deserves its on thread.
It seems that all time favorite among Euro enthusiasts has LL01 again, and even better, pour point of -60 indicates high % of PAO.
https://msdspds.castrol.com/bpglis/...D50FF12802588DE005BE9D3/$File/bpxe-a9tnq9.pdf
US PDS:@edyvw, Current specs on the official Castrol website are a bit controversial.
The product data for Castrol 0w30 A3/B4 is from 17 Oct 2022 which is older version of this oil (pink version). However, there is discrepancy between the Product Data Pour Point -60 °C dated 17 Oct 2022 and MSDS Pour Point -45 °C dated 04/21/2024.
This makes me think that new "Gold" container has reduced PAO similar to new 0W-40.
This is the new Product data I found dated 17 Nov 2023 for the "Gold" container and that matches MSDS data
https://msdspds.castrol.com/bpglis/...C8AD60880258AD9003BB3F9/$File/wepp-d3a89m.pdf
Most likely new gold (API SL) 0w30 has reduced PAO and old pink (API SL/CF) version is better.
The US PDS the you mentioned has date 17 Oct 2022, check at the bottom of the last page. That what I was telling in my previous post. The updated PDS from 17 Nov 2023 says Pour Point -45 °C. Global English PDS: https://msdspds.castrol.com/bpglis/...C8AD60880258AD9003BB3F9/$File/wepp-d3a89m.pdfUS PDS:
US MSDS:
https://msdspds.castrol.com/ussds/a...2625D6F617E80258B070052B59A/$File/3088903.pdf
UK PDS:
UK MSDS:
https://msdspds.castrol.com/ussds/a...467FC4DAD1680258B070052C6EE/$File/3088800.pdf
Could it be new version? Perhaps. But Castrol US still claims -60c pour point.
I know pds is from Oct 2022. German PDS for the new 0W30, with -45c, is also in October 2022. If you go to German Castrol web site you will see PDS being from 2022. Also, US MSDS is slightly different and that one is from April 2024.The US PDS the you mentioned has date 17 Oct 2022, check at the bottom of the last page. That what I was telling in my previous post. The updated PDS from 17 Nov 2023 says Pour Point -45 °C. Global English PDS: https://msdspds.castrol.com/bpglis/...C8AD60880258AD9003BB3F9/$File/wepp-d3a89m.pdf
They have old PDS link on their product page. The new has less PAO, same as 0W-40. Many companies these days cut corners.
Is Castrol Edge 0w30 A3/B4 API SL/CF (pink) better than 0W-40 API SN (2022) for daily driver with occasional 5000rpm?
Can't find PDS for old 0W-40.
Edited my comment a bit at the same time you posted yours.I know pds is from Oct 2022. German PDS for the new 0W30, with -45c, is also in October 2022. If you go to German Castrol web site you will see PDS being from 2022. Also, US MSDS is slightly different and that one is from April 2024.
Not sure whether occasional 5,000 rpms play any role, when I use either Castrol, and any other oils, I run it several times a day to 7,000rpms. Whichever you get, make sure your oil temperature is at the operational level. If you track you car, I would go 0W40 in that case.
It is possible that they were selling old version up until this year. Also, it is possible they updated MSDS but not pds.Edited my comment a bit at the same time you posted yours.
One more thing that I also mentioned - the latest version of US MSDS also says Pour Point -45 °C. And lower flash point - 203°C (397.4°F) [Pensky-Martens ASTM D 93]. These facts are also important.
Found it, PDS for 0W-40 API SN/CF (2019) https://msdspds.castrol.com/bpglis/...39CEBFB802584C6007D7CE6/$File/bpxe-bjlw36.pdfIs Castrol Edge 0w30 A3/B4 API SL/CF (pink) much better than Castrol 0W-40 API SN (2022 version) for daily driver with occasional 5000rpm? I think benefits would be better oil performance if engine often doesn't reach operating temp, better MPG. What are the reasons to pick 0W-40 other than for racing/track purpose?
Can't find PDS for old 0W-40 by the way.
| Characteristics | 0W-30 | 0W-40 |
| Viscosity, Kinematic 100C, mm²/s | 12.18 | 13.2 |
| Viscosity, Kinematic 40C, mm²/s | 73.21 | 74 |
| Viscosity, CCS -35C (0W), mPa.s (cP) | 5880 | 5600 |
| Noack Volatility, % Loss | 8.3 | not specified but other sources say 8.6 |
| Viscosity, HTHS 150C | 3.5 | not specified but other sources say 3.6 |
| Pour Point | -60 | -57 |
| Flash Point, PMCC, ASTM D93, °C | 210 | 209 |
SN Noack is 9.1% and HTHS is 3.7cP.Found it, PDS for 0W-40 API SN/CF (2019) https://msdspds.castrol.com/bpglis/...39CEBFB802584C6007D7CE6/$File/bpxe-bjlw36.pdf
PDS For 0w30 API SL/CF (2022)
Characteristics 0W-30 0W-40 Viscosity, Kinematic 100C, mm²/s 12.18 13.2 Viscosity, Kinematic 40C, mm²/s 73.21 74 Viscosity, CCS -35C (0W), mPa.s (cP) 5880 5600 Noack Volatility, % Loss 8.3 not specified but other sources say 8.6 Viscosity, HTHS 150C 3.5 not specified but other sources say 3.6 Pour Point -60 -57 Flash Point, PMCC, ASTM D93, °C 210 209
Very similar oils. 0W-40 is a bit thicker that may be helpful for frequent driving with high RPM. 0w30 has advantage in MPG and cold engine run. Sadly both oils are only available until old stock is sold out.
Also if these VOA are correct, 0w30 is mostly Calcium (2340) based while 0w-40 is mix Calcium (1656) Magnesium (445) which may have an advantage over 0w-30. What is your opinion?SN Noack is 9.1% and HTHS is 3.7cP.
After bumping into the thread below decided to do more research. I believe Castrol decided to cut the costs with their retail oils and 0w30 0w40 are no longer as good as they used to be. However, after they signed a contract with BMW they could at least make an effort to provide good branded oil. Remains a question whether 5w30 is made by shell or castrol, but the 5l bottle is from castrol, wonder if they mix GTL for BMW or it is just a castrol-style bottle with shell oil in it.They changed their 0w-40 formula after 2017. Magnesium version had rings on the bottle. Interesting, why would they go to full calcium.
BMW N55 is said to not be a victim of LSPI, but it is DI turbo and there are post saying that it may occur in specific circumstances, like tuned engines where DME cannot handle certain cases properly.
May be it's worth to stockpile on 0w30 while the old stock is still available. After I switched from TPT 0w30 to Castrol 0W-40 (bmw F15 N55) I noticed that on cold start the engine runs with a bit more vibration and knocking. Castrol 0w30 may work better.
Castrol is US.After bumping into the thread below decided to do more research. I believe Castrol decided to cut the costs with their retail oils and 0w30 0w40 are no longer as good as they used to be. However, after they signed a contract with BMW they could at least make an effort to provide good branded oil. Remains a question whether 5w30 is made by shell or castrol, but the 5l bottle is from castrol, wonder if they mix GTL for BMW or it is just a castrol-style bottle with shell oil in it.
https://bobistheoilguy.com/forums/threads/voa-bmw-ll-01-twinpower-turbo-5w30.365608/
Those who work on documents at Castrol have lack of competence. I just noticed that same as for 0w30 they also have mismatched data for 0w-40 in PDS (Pour Point °C -45, 28 Apr 2024) and MSDS (Pour point -57 °C, 12/19/2023). If these test results are true, then it proves that Castrol changed the formula and amount of PAO beginning 2024 for both 0w30 and 0w40.It is possible that they were selling old version up until this year. Also, it is possible they updated MSDS but not pds.
I have bunch of Motul on my shelf for next 3yrs including 300V. I have also 10qt of Castrol 0W30 from like 3yrs ago.Those who work on documents at Castrol have lack of competence. I just noticed that same as for 0w30 they also have mismatched data for 0w-40 in PDS (Pour Point °C -45, 28 Apr 2024) and MSDS (Pour point -57 °C, 12/19/2023). If these test results are true, then it proves that Castrol changed the formula and amount of PAO beginning 2024 for both 0w30 and 0w40.
Did you switch to Motul 5W40 300V? That's what your signature says.
