5w20 is priced the same here as the regualar conevetional oil - Valvoline, Citgo, Penzoil - No difference in price. Valvoline and Penzoil around 1.70 or so, Citgo around $1 and some change.
True in this regard: Ford requires either a double-length (160 hours) Sequence IIIF test or a double-length (128 hours) Sequence IIIE test with a maximum viscosity increase of 200%. The corresponding limits for the single-length tests are 275% maximum and 375% maximum, respectively. In addition, Ford’s limit for high temperature deposits in the TEOST MHT-4 test is 30 mg maximum compared with 45 mg maximum allowed under API SL/ILSAC GF-3. The Sequence IIIF engine test as part of ILSAC GF-3 replaces the Sequence IIIE engine test. This test evaluates oil thickening, piston deposits, and valve train wear under high speed, high temperature conditions. Test length has been increased from 64 hours to 80 hours, and pass/fail limits have been tightened. Maximum viscosity increase has been reduced from 375% at 64 hours to 275% at 80 hours.quote:
Originally posted by Bill in Utah:
he stated that the 5w-20 is better oil than 5w-30.
Cheers! Bill
Cold 5W-20 is thinner than cold 5W-30.quote:
So how can a HOT 5w30 harm an engine when a thicker, COLD 5w20 is fine at start-up? Thanks for jumping in!
For all intents and purposes, Mobil 1 5w30 is practically a 5w20 anyways. It's only 0.4cst thicker than a 5w20. The difference in fuel economy between 5w30 Mobil 1 and most 5w20s on the market wouldn't even be more than 1/10th of one MPG.quote:
Originally posted by Americanflag:
Wouldn't 5@-30 Mobil full synthetic offer as good or at least similar fuel economy benefits as a 5W-20 blend? That is what Mobil 1 told me.
Also, wouldn't a full synthetic 5W-30 like Mobi1 offer at least as much protection at start up as a 5W-20 blend?
I don't own a car that requires 5W-20 but I see two potential issues that maybe you are missing:quote:
Originally posted by Whimsey:
Ok, maybe I'm missing something. But if Ford requires their spec oil, whether Motorcraft or others that meet's their warranty requirements why are people getting bothered and upset about using them during the warranty period. If you want to argue with Ford about using another spec. oil during the warranty period go ahead, but if they void your warranty you can only blame yourself. What you do after your warranty period is up to you. At this point in time the Ford Motorcraft 5W-20 oil has been good, according to UOA, and I see no reason to change oil brandor grade until my warranty is up, then I'll decide what oil is best suited to my needs. I agree that this oil grade is not for everybody.
Whimsey
For one, having a 3.3 HTHS! That's better than Mobil 1 10w30! Redline's 5w20 looks to be better than most 5w30s and 10w30s out there.quote:
Originally posted by sprintman:
Terry i'm looking at the specs. What part is 'incredible'?? tks...s
They are always on my mind, thanks to that free t-shirt they sent me last year, which I wear around the house all the time!quote:
well spotted. Looks interesting for sure. A lot of Redline related posts on here lately, they seem to be grabbing more 'mindshare'.
