Caliper pin boots
Near the beach in Delaware
I did one side of side the rear brakes of my pickup today and the boot that was on the caliper had one end of the boot with a larger opening than the other. Sure looks like both ends should the same as the smaller end. The shoulder of the caliper pin that is covered by the boot had more rust than I would have expected.
I have owned the truck since it had 30K on the clock and it now has 114K. I have never done the rear brakes.
So unknown. Came from the factory with wrong boot? Someone before me did the rear brakes and used the wrong boot? At 30K I would doubt the boot needed to be changed.
This was a pad slap. When I do the pads and rotors I will get new pins and boots.
Most likely scenario, I'd guess. The factory receives the brake caliper assemblies fully built meaning an error would have had to come from the brake vendor. Those assemblers see the same, identical component hour after hour and would (should) notice the slightest variation or something wrong.
I had to replace a caliper bolt on the civic. I noticed one of the boots appears to be damaged since it isn't fitting snugly when I reassembled.
Do you guys recommend OEM boots for the slider pins only?
I realize you can't always rely on what the other side looks like, but was it the same?
Came from the factory with the wrong boot would be my guess. If the brakes were changed at 30,000 miles or before you bought it, they wouldn’t have replaced those boots anyway unless there was something wrong (doubtful at that mileage).
But if you put it back on with the boot, I’d be careful to add plenty of grease because you don’t want the hassle of dealing with a frozen caliper pin later done the line.
No matter how much grease you put on the pins, when you install them most the grease will wind up in the boot because the pin to bore clearances are small.
It could be that the guy that did the brakes before used a lube that was not compatible with EPDM rubber and the lube had more contact with the outer one. This is exactly what happens to EPDM when petroleum based lubes come in contact with it over a longer period.
Both sides of the boot should be the same.
Some of the aftermarket stuff is fine just get a brand name.
  • Like
Reactions: JC1
Yes swelling of the boots is common, esp if the pins ever got regreased with a petroleum product
I will be taking out the caliper pin and boot and replacing both. With the opening too large the shoulder area of the caliper pin had rust on it as there was not a good seal.
I am surprised there is not a recall on this. But truck was made in or made for sale in Canada. Maybe recalls are different up north?
All 4 boots were identical. Larger opening at one end.
That’s true, I was thinking more along the lines of add more grease, hope that it builds enough of a barrier to prevent some rust from forming on that pin.
The grease will tend to migrate to the outer part of the boot if that is where the larger end is.
